Oil Sending Unit Removal Question???
Old Mar 19, 2011 | 04:43 PM
MikeWidd's Avatar
MikeWidd
Default Oil Sending Unit Removal Question???
Does anyone know what it takes to remove the Oil Sending Unit? I can barely see it let alone, Know what I need to take it off.
Old Mar 19, 2011 | 10:02 PM
revvinram's Avatar
revvinram
1) Special socket to fit Oil sending units
2) Ratchet, Extension and a swivel adapter.
3) Make sure the engine is cold and take off air box and work by feel..
4) It took me longer to get the damn thing unplugged then to change it..
Good Luck!!!
Old Mar 20, 2011 | 12:28 AM
MikeWidd's Avatar
MikeWidd
I'll answer my own question. It takes an 1 1/16 deep socket.
Old Apr 5, 2013 | 06:57 PM
at800mev's Avatar
at800mev
Default unplugging
Good Luck!!!
How did you finally unplugger the connector? It looks like there is a red plastic "pin" that needs to be removed or something like that?
Old Apr 5, 2013 | 07:18 PM
dhvaughan's Avatar
dhvaughan
the red tab is a sliding lock.
remove air filter.
climb up in there.
rotate the plug wires apart to create a little space.
locate the damn sensor and get you hand on the electrical connector.
slide the red tab sideways. you'll feel it click.
remove the connector upwards. i don't think there is a squeeze tab.
use the 1-1/16 socket and a moderate extension to replace.
Old Apr 5, 2013 | 08:29 PM
Arde's Avatar
Arde
I was able to remove mine with an open end wrench angled down between the block and firewall. Once it was loosened, I was able to finish removal without a wrench. A PITA for sure.
Old Apr 6, 2013 | 01:17 PM
at800mev's Avatar
at800mev
remove air filter.
climb up in there.
I am trying not to break the tab. It is on the passenger side of the connector. Does it slide forward or to the rear of the truck to unlock? So far, no click. Before I use "excessive force" I would at least like to know I am trying in the correct direction. Thanks!
Old Apr 6, 2013 | 01:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
IIRC, it slides up. Not to the back,front or side.
Old Apr 7, 2013 | 07:14 PM
dhvaughan's Avatar
dhvaughan
i was thinking it slides side to side, rather than up and down, but --- i could be wrong.
don't use any excessive force. just gently slide it whichever way it wants to go. it takes very little finger pressure.
Old Apr 7, 2013 | 07:28 PM
guzman's Avatar
guzman
Default Mirror
Get a small mirror and flashlight so you can tell which way the red sliding lock moves. The parts stores sell ones that telescope and swivel with about a 2" head for around $10, very good item to have around the shop for many uses.
