swapping nv3500 for 46re
Old Jul 5, 2011 | 12:09 AM
  #21
Raminator2001's Avatar
Raminator2001
im at the end of this swap on a 2001 sport 318 NV3500.drive shafts,crossmember,transfercase are all the same length,ive set everything side by side,crankshaft positioning sensor is different from auto/man.
The input shaft on the auto transfercase is shorter than the one in the manual,i was able to swap these out along with the input bearing.The pilot bearing needs to be one with a sleeve,the simple needle bearing alone that came with my LUK clutch kit wouldnt work.
my big problem at this point is my speed sensor,the auto is in the trans(2 prong connector),the manual is in the transfercase (3 prong connector)need to find schematics on senor connections for each pin.
Old Jul 5, 2011 | 10:38 AM
  #22
Grab the factory service manual from the FAQ section here. It will have the pinouts you need.
Old Jul 5, 2011 | 11:22 AM
  #23
Raminator2001
already checked the pinouts in the pdf file but it dosent show anything for the 3rd pin.where does that wire connect,it only shows the 2 pin connection for auto & man.
Old Jul 5, 2011 | 11:33 AM
  #24
Yer right. They don't differentiate between manual and auto at all. There is nothing there about the manual being different. The PCM only shows two wires that it cares about as well....... I don't know. You will probably have to trace the wire to where it goes......
Or, just hook up the two the PCM DOES care about, and see if it works......
Old Jul 5, 2011 | 12:25 PM
  #25
Raminator2001
i cant even find a picture of the 2 pin style with the gear drive,better yet autozone.com dosent even show this style.
pic below is the autozone listing Dorman/Sensor - Transmission Speed
For your 2001 Dodge Truck RAM 1500 1/2 ton 4WD 5.2L SFI 8cyl
Part Number: 917-602
Old Jul 5, 2011 | 12:26 PM
  #26
Raminator2001
This is what i have at the transfer case for a speed sensor
http://cgi.ebay.com/ebaymotors/Airte...mZ320697976962
Old Jul 5, 2011 | 10:40 PM
  #27
simidrm's Avatar
simidrm
I'm pretty sure the speed sensor is in the rear end,dodge stopped putting them in transmissions in the early 90's.
But if it is like a 47re the 3 wire plug is simple the outer 2 wires are backup lights,the middle wire serves 2 functions, 1. is a neutral start for a automatic,and 2. sends a signal back to pcm that the vehicle is in gear so the cruise control will work,so it has to be grounded (park) to start and ungrounded (drive) for your cruise to work.
Old Jul 5, 2011 | 10:55 PM
  #28
simidrm's Avatar
simidrm
Originally Posted by simidrm
I am actually in the process of doing this myself,I bought a nv5600 and transfer case,the whole swap kit off ebay minus the pcm,so far the most trouble I've had is the darn pedals were a bear to change,the pcm on a diesel only controls the guages,cruise control,the engine has it's own ecm,the speed sensor is in the rear diff,so the only thing to rewire is clutch neutral switch which is simply a ground,and reverse lights,and of course the hole in the floor thing. but so far I have only gotten to the pedals,I removed all automatic parts first, cooler,lines,transmission,transfer case etc....
Well the truck has been done now for several months,so far with no problems or check engine lights,still using auto pcm and everything but my cruise works,which even that is an easy fix,the middle wire from the 3 wire plug needs to be routed back to the switched side of the clutch safety switch.
The auto starter was reused with a spacer and longer bolts,got a manual front drive shaft,reused the old rear drive shaft by cutting it down 5 1/2 in.
total time was about 12hrs.
I have my old tranny,transfer case and other parts I took out if anyone needs anything oh minus the tranny lines I ended up cutting them to get them out.
Actually thinking of selling truck to get a newer one but darn I went from 18.5 to 23.1 mpg doing swap my email is simidrm45844 at yahoo.com if anyone needs parts or have any question on doing swap.
Old Jul 5, 2011 | 10:56 PM
  #29
atthewmartin114's Avatar
atthewmartin114
there is a whire extention you can get from the dealer that goes into the end of the auto wire whip and its plug and play
Old Jul 6, 2011 | 12:18 AM
  #30
Raminator2001
simidrm my reverse lights are on a separate plug,i have them wired already,same as the NSS,this plug i have issues with is located in the transfer case(controls speedometer)
