Got a few questions.
Old Mar 21, 2011 | 11:14 AM
Originally Posted by Twilliams22
okay. I think if im going to get the trans rebuild im going to take it to my tech and see if we can do it there.
but is there anything i should try to do before i just go and rebuild the trans. thats kinda my last resort. you know what i mean?
Before you do that........ Unplug the eight pin connector on the drivers side of the trans, take the truck for a ride, you will have to shift the gears manually, there will be NO automatic function AT ALL. If it shifts when you tell it to..... replace the governor pressure sensor, and solenoid. (and while you are in there, adjust the bands, change the filter...) If it doesn't, THEN start looking for a rebuilder.
Originally Posted by torike
Hi gays.
I am writing from Hungary. I am a collector.
The appertaining have a Dodge Ram 1996 edition of Indianapolis car handler.
Where can I beszerezeni authentic certificate, that the car was really Indiannapolisban handler car?
The Dodge Ram Information:
Year: 1996
VIN: 3B7HC2670TM147009
Color: White
Transmission: Manual
Engine type: Magnum
Can anyone help on where I can obtain that document, that the car is really the year of 1996 Indianapolis car was the handler?
Email dodge directly, give them your vin number, and they will send you a build sheet for the truck, that will tell you EXACTLY what it came with from the factory. (well, power rack and pinion steering aside....... )
Old Mar 21, 2011 | 07:00 PM
Twilliams22's Avatar
Twilliams22
Okay thanks guys. I'ma try to save some money for it.
but one more question if you don't mine.
So when i unplug this 8pin and try to shift it manualy and if it DOES work thats when i WANT to replace the governor pressure sensor and solenoid?
just making sure i have this right when i go to check it.
Thanks again guys.
~Tyler
Old Mar 21, 2011 | 07:08 PM
That is correct.
Old Mar 21, 2011 | 07:10 PM
UnregisteredUser's Avatar
UnregisteredUser
Yep, that's correct.
HeyYou's mad ninja skillz are in fine form today...
Last edited by UnregisteredUser; Mar 21, 2011 at 07:11 PM. Reason: Too slow for the ninja!
Twilliams22
Thanks for all your help. everyone.
Ill try to keep you guys updated because i know how annoying it can be when someone doesn't.
but it might be awhile. I'm broke . ahaha.
~Tyler
Old Mar 22, 2011 | 11:32 AM
Twilliams22
okay i was looking for this 8pin connector on alldata's website. would this 8pin be called the Governor Pressure Sensor?
~Tyler
Old Mar 22, 2011 | 11:34 AM
The governor pressure sensor and solenoid are part of what that connector goes to. Disconnecting it causes the system to default to max pressure. So, no automagic functions at all.
Old Mar 22, 2011 | 12:07 PM
Twilliams22
so i was looking again to see what could cause some problems could it be the TPS? and maybe if i just cleaned the governer pressure sensor/solenoid
Old Mar 22, 2011 | 12:11 PM
That's possible.... There is a DIY in the faq section for cleaning the solenoid. Sensor isn't really serviceable.
Old Mar 24, 2011 | 09:54 PM
dhvaughan's Avatar
dhvaughan
^tps? i doubt it. does the engine rev up correctly when you mash the gas pedal? that's more or less all the tps does, is tell the computer where the pedal's at so it can increase fuel and timing.
