WTF battery died and then truck started running like crap
Old Mar 20, 2011 | 02:34 PM
BlueBeast2's Avatar
BlueBeast2
Default WTF battery died and then truck started running like crap
I went on a brush fire and has some of my blue lights going. I shut it off of course, which I've done before. Well I go to leave and it's dead. I had to get jumped and then it didn't wanna stay running. The A/F was all wacky running major rich. Then it didn't wanna stay running when I let off the gas. I got it to idle and hit the gas a few times and it would die. I let it run a while so hopefully it charged up the battery.
Anyway would a low battery make it run like that? Greg seems to think it would. I'm not so sure about all that. I still gotta run outside in a bit and see how it starts. It was starting funny with the key but with the remote start it fired right up
Old Mar 20, 2011 | 02:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Dude, let the PCM relearn.
Old Mar 20, 2011 | 02:45 PM
BlueBeast2's Avatar
BlueBeast2
how i do that?
Old Mar 20, 2011 | 03:23 PM
Just drive it.
Although, if it won't idle after the battery dies, need to have a look at the IAC motor.
Old Mar 20, 2011 | 03:51 PM
redheadhunter21's Avatar
redheadhunter21
weak batteries wreck havoc on our trucks, test battery if good charge it up all the way and drive it for 200 or so miles if not driving right then get back on here
Old Mar 20, 2011 | 04:46 PM
BlueBeast2's Avatar
BlueBeast2
Took it for a spin and it seems to be ok I guess. Once in a while when coming to a stop the idle will drop lower then usual but it's not dying now. I had an issue before with the idle dropping lower then normal so I can live with it. Hopefully that goes away after a while too
Old Mar 20, 2011 | 06:07 PM
Truedge's Avatar
Truedge
I had this happen to me as well. I accidentally left my parking lights on and killed the battery. It took a trip around the town and out to my buddies place just to get it running right.
Old Mar 20, 2011 | 09:02 PM
ghost4321's Avatar
ghost4321
The alternators do not produce enough power to run the truck at idle, it's acting like that cause it's trying to run off the battery which is almost dead. Drive it for a while and it will be fine. If it doesn't clear up get the battery tested.
Old Mar 20, 2011 | 10:19 PM
Justin3's Avatar
Justin3
I would check out your whole charging system, put a voltmeter on the battery while the engine is running, you should have a steady 14+ volts charging the battery, anything less or if it fluctuates your alternator is on the way out. I do a lot of night calls so I always leave my blue lights on, but I have leds so they don't draw much power... If you want an extra boost for your light bar, invest in one of the optima batteries.
Old Mar 20, 2011 | 10:34 PM
PurplDodge's Avatar
PurplDodge
Normal when your battery dies. Just drive the hell out of it.
