Cam and Lifters
Old Mar 26, 2011 | 02:46 PM
Adobedude's Avatar
Adobedude
man are cams for 2nd gen ram expensive or what? i was just looking on summit and the cheapest cam was like $310. i have been looking at cams and kits for my 81 and the cheapest cam was about $63 and the cheapest cam and lifter kit is $111.
You can get a stock Roller cam reground for about 150.00. I just sold a Mopar RT cam for 50....Used cams show up.
Old Mar 26, 2011 | 02:59 PM
lazyboy's Avatar
lazyboy
well reground sounds like a good option to check into esp with the sausage cam numbers given and proven. next question what rocker ratio is suggested with the sausage cam?
just ordered all to button up the bottom end, this is getting exciting... whoo hoo
Old Mar 26, 2011 | 03:18 PM
Adobedude's Avatar
Adobedude
You can get it ground for either 1.6 or 1.7.
The stock stamped steel rockers are 1.6, you could use them at a loss of some HP (friction loss) but your pushrods will have to dead nusts on.
BTW...The Sausage Cam was named after the guy on the original Dakota R/T forum whom designed it, Jim Marshall. AKA Jimmy Sausage.
Just so you know...LOL
Old Mar 26, 2011 | 05:59 PM
Its the gears in the diff that can kill ya. Too low (numerically) of a ratio, with large tires, and it takes quite a bit to get the truck rollin'.
