Shackle flip complete
Old Mar 30, 2011 | 06:59 PM
EndIsNear's Avatar
EndIsNear
Originally Posted by tweeker909
You would have better luck winning that lottery. Theres all ways tomorrow to search for a pic..
Complete? Incomplete i think you ment to say. Why incomplete you should ask? Axle pushed forward not centered. Zero rate block to call this complete.
What the hell are you talking about? My axle is very much centered as should be.
Old Mar 30, 2011 | 07:26 PM
tweeker909's Avatar
tweeker909
Think you need to take another look @ your rear. It is very much uncenter/pulled forward about 1-1 1/2.
http://www.pirate4x4.com/forum/showthread.php?t=537571
Old Mar 30, 2011 | 10:02 PM
EndIsNear's Avatar
EndIsNear
No, its not. I went and observed it. From the angle of the picture, yes it looks like it. But looking at it from the side, directly, it is centered exactly.
Old Mar 31, 2011 | 07:23 AM
olyelr's Avatar
olyelr
If you did indeed gain some lift from the flip, and did not lower the front mounts the same distance as the back, then yes your axle will be off center... it the simple law of physics.
When a shackle flip is installed such as a the BDS setup (which gains about 4-5" of lift), it will literally push the axle to the front of the truck a few inches. Thats because it drops the rear leaf springs mount so much yet doesn't move the front mounts at all. Since your setup did not drop the mounts that much your axle will not move quite so much... but it did move some (unless you lowered the front mounts too).
Thats what they sell zero rate blocks for. They allow the axle to be re-centered in the wheel well, by allowing the axle to be mounted in a different location on the spring.
Old Mar 31, 2011 | 08:36 AM
EndIsNear's Avatar
EndIsNear
I see. Well that makes sense. But only gaining 1-1.5", possibly 2", really pose a problem? The axle looks unchanged. Im not going any higher with it, so anything I should worry about?
Old Mar 31, 2011 | 12:41 PM
If it moved a tenth of an inch or so, I would be surprise.
Nothing to worry about at all, only thing to concern yourself with is make sure pinion angle is where it should be.
Old Mar 31, 2011 | 12:51 PM
tweeker909's Avatar
tweeker909
Not if you want to do it correctly. Iam very curious cuz in the pic its very much off centered. Post a pic straight on with a measurement on both sides back to the wheel wells. ILL bet its about an 1" or more forward. But hey i no nothing cuz i have 72 well after deletion 68 posts lol
Old Mar 31, 2011 | 12:59 PM
The axle is located by the front leaf spring mount, and rotates in a shallow arc around that mount as it travels up/down. Raising the truck an inch or so might have moved the axle a MAX of half an inch. Maybe. If you like, I could do up the math, and tell you EXACTLY how far it moved.
Regardless, the axle has only moved in its normal arc of travel. It isn't really an issue.
Old Mar 31, 2011 | 01:04 PM
tweeker909's Avatar
tweeker909
And how many shackle flips how you done? Is this from experience or just what you have read on the www sitting in an armchair? PLZ enlighten us on the math.
Old Mar 31, 2011 | 01:28 PM
EndIsNear's Avatar
EndIsNear
Well, I can definantly tell you it didnt move an inch. I took some pics, give me a while to upload them. My phone is slow where I live
