1996 ram 5.2 trans fluid temp sensor code
Old Mar 30, 2011 | 05:06 PM
sledhead558's Avatar
sledhead558
Default 1996 ram 5.2 trans fluid temp sensor code
have a 96 ram 1500 took to shop to have tranny serviced code p0713 was on scanner tech said tranny needed to be rebuilt don't notice any slipping he said code is overheat code said not to service would get worse with new fluid tookit home let truck cool down put scanner on started truck code came back again reset hour later tried again same code today tried it has sat 24 hours hooked up scanner sarted truck code p0711 temp sensor circuit range performance I assume if I let it warm up code 713 will come back what is causing this shold I service tranny and change sensor
Old Mar 30, 2011 | 05:16 PM
Sounds like either the sensor is going belly up, or, your check valve is clogged.
Get rid of the check valve. You will find it in the trans line, up by the radiator, goes to the bottom of the radiator trans cooler. Just yank the line that is in there now, (flare nut on one side, dodge specialty connector on the other, 3/8ths, can get the release tool from any parts store.) and replace it with a length of hose, and some hose clamps. (make sure you get the right type of line.... needs to be able to tolerate trans fluid.)
Check valve should go regardless of what else you do.
See if that doesn't improve its attitude any.
Old Mar 30, 2011 | 07:09 PM
sledhead558
wanted to service fluid dirty shop said tranny wil probably fail
Old Mar 30, 2011 | 10:56 PM
What does your fluid look/smell like? (although, ATF +4, those are supposedly meaningless.....)
If the trans is still behaving itself, figger out why the temp code is being set. (P0711) If the sensor, or the circuit is causing trouble, anything else that it tells you is suspect.
Solve that one first. If the wiring all looks ok, replace the sensor. While you have the pan down, do the filter (you don't get a choice on the fluid. ) and adjust the bands while you are at it.
Old Mar 31, 2011 | 05:18 PM
sledhead558
will service and see what happens
Old Apr 3, 2011 | 06:42 AM
gdamtbnms's Avatar
gdamtbnms
i threw a trans temp sensore code and since it was cheap i replaced it and the code went away. I wouldnt change the trans fluid! this def might cause slipping that wasnt there to begin with! you will lose some trans fluid but not all of it. Also, if you do buy a new sensor dont buy the one from auto zone or advance, its the wrong part! go to the dealer! Most likely they will have it in stock! i have a 96 and i got lucky
Old Apr 3, 2011 | 06:13 PM
sledhead558
dealer said the sensor was inside the tranny is that correct part is 118.00
Old Apr 5, 2011 | 05:33 AM
gdamtbnms's Avatar
gdamtbnms
I have a 96 and my sensor was screwed into the trans pan and has a plug. def not in the trans. trans coolant temp sensor right? idk maybe my truck is different or i'm thinking of a different part. I have a 5.9 4x4 96 ram auto
Old Apr 5, 2011 | 05:55 AM
tweeker909's Avatar
tweeker909
Gov pressure sensor inside the tranny doubles as the temp sensor on 46re's.
