problem getting key out of ign.
Old Mar 30, 2011 | 11:17 PM
sullivanj04's Avatar
sullivanj04
Default problem getting key out of ign.
so in order to get the key out or in you have to pull up on the shifter that and the gear selector on the dash doesnt line up, is there a way to adjust any of this?
thanks
Old Mar 30, 2011 | 11:26 PM
PurplDodge's Avatar
PurplDodge
You have to have the shifter in park and the steering wheel unlocked to pull the key out, is that what you are meaning?
Remove the three screws on the bottom of the knee bolster (the large plastic piece where your knees are under the steering wheel and pop it off. You will see a white tube with a copper colored wire attached to the steering column. There will be a thumbscrew on it, mess with it see where it gets you.
Old Mar 30, 2011 | 11:28 PM
Adjust your shift linkage.
BLOCK YOUR WHEELS. Put the shifter in what it thinks is neutral. Crawl under the truck, and loosen whatever holds the linkage in place for adjustment. (I haven't had to deal with this yet, so, not sure what all it looks like, on the chevys i have done, is was a nut you loosing up a bit, so you could slide a shaft in/out of a pivot...)
Make sure the trans shift linkage is in the center of the detent for neutral. Crawl back out, and put the shifter in the notch for neutral. Crawl back under, tighten whatever you loosened.
There is also a way to adjust the little orange indicator so IT is in the right place, think there is a DIY in the faq section for that.
Replace any worn bushings you find while crawling around down there too.....
97tn4x4's Avatar
97tn4x4
I had this very problem about 2 months back. Does the trans still shift good? I hope for your sake it's just an adjustment, mine was the trans the 2nd gear band strut or something broke and fell on the shift selector in the trans. If you crawl under the truck and look at the linkage you'll see the adjuster.
Old Mar 30, 2011 | 11:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The indicator has an adjusting screw up behind the knee panel. I think the shifter mechanism is just plain worn out, so I don't think it will make any difference.
Old Mar 30, 2011 | 11:36 PM
sullivanj04
the guy I bought it from said it started to do it after he had the tranny rebuilt so ill check the shift linkage in the morning. it shifts fine. does the selector in the dash control the key release or would the linkage effect that?
Old Mar 30, 2011 | 11:45 PM
sullivanj04
and yeah its in park but in order to get the key out you have to lift the shifter up to get the key out and i dont want to end up breaking somthing doing this all the time
Old Mar 30, 2011 | 11:46 PM
zman17's Avatar
zman17
The shift lever in the column itself has a mechanism that interacts with the ignition switch. Pull the covers off and see what is worn.
