End-all Be-all plenum thread
Old Feb 17, 2012 | 09:51 AM
  #241
For the broken bolts, put vice-grips on em, hit 'em with chemicals, and tap on the end of the bolt with a hammer while trying to get them to break loose.
Old Feb 17, 2012 | 09:54 AM
  #242
i mow grass's Avatar
i mow grass
Originally Posted by Wh1t3NuKle
Grass Mower! Good work with how much you've done. Are the bolts still protruding from the block? Just get a good grip with vice grips. Even spray some catalyst in the threads. You should be able to easily extract that way. For cleaning, brake cleaner is good to spray on and then use a razor blade. It makes a great flat edge. Scotch brite pads are good too, especially if you need to put more elbow into it. Definitely finish with razor blade.
Yeah they are sticking up about 3/4" I blasted them with PB last night and will hit them again when I get home and hopefully they will pop right out. Will a scotch bright not make high/low spots?
Old Feb 17, 2012 | 02:56 PM
  #243
stewie01's Avatar
stewie01
I gotta wonder about all the broken bolts while doing a plenum job. I know rust from snow/salt and whatnot is a factor, but all of mine came out easy peasy.
And I didn't use a single shot of chemicals. I did buy a new can of PB Blaster, and never got to use it.
Old Feb 17, 2012 | 03:25 PM
  #244
Basically it boils down to pure luck. I broke two, both front bolts.
Old Feb 17, 2012 | 03:33 PM
  #245
i mow grass
Just the heads? Or did you break it a little bit down the shaft?
Old Feb 17, 2012 | 03:36 PM
  #246
Far enough down that I had to drill 'em out, and then blow out the rest with a torch..... That was fun......
Old Feb 17, 2012 | 04:28 PM
  #247
Nereaga's Avatar
Nereaga
Originally Posted by JOSV650S
Hmmm I'm thinking I'm going to need to do mine 99 Ram 1500 4X4 5.2L. I've been getting random misfires for months...CEL will come on for a week, then go way. Uses oil but no smoke out the tail pipe, feels down on power; especially when I really put my foot into it.
Sure looks like a blown plenum to me...have no idea when the PCV valve was done last, but I'm thinking that looks like too much oil to be PCV valve related. I opened up the butterflies on the TB and snapped a couple pics.
Now correct me if I am wrong, but are you supposed to see that much fluid sitting in there? It looks to be clear from the pics... What else could cause that?
Old Feb 17, 2012 | 06:27 PM
  #248
JOSV650S's Avatar
JOSV650S
Yea I thought it was very strange also. Its the color of brand new oil basically, it wasn't dark like I was expecting.
The truck seems to eat a lot of oil, I haven't been keeping track of what it's actually using...but everytime I check the dipstick it is barely visible on the dipstick and needs a quart or more sometimes to bring it up back to the appropriate level.
The truck doesn't smoke at all, so I'm thinking it has to be going into the intake and probably clogged up my cat.
I've put a new coil on it, new wires, new cap and rotor, and new plugs so I know the issue isn't ignition related.
Maybe I need to pull the whole throttle body off and get a better view down there?
Old Feb 17, 2012 | 06:40 PM
  #249
JOSV650S's Avatar
JOSV650S
Your pictures appear to show the oil as quite fresh and liquid. PCV oil would be kind of brownie, caked on texture. Might try to take your extending magnet stick or former antenna or similar and put a portion of shop towel on the end. Tape it on to old the wad. Stick down to plate and collect some to get an idea of the oil.
If it is plentiful and liquid like that, then it sure would indicate a leaking gasket. If you haven't seen, here is a thread that shows a collection of the plates (intact and blown) to help you out.
https://dodgeforum.com/forum/2nd-gen...s-post-up.html
Thanks for the info! I'll have to try that out. I browsed through that picture thread and I'm thinking mine looks alot like this one posted from that thread:
Clean, wet looking pool of oil.
http://imageshack.us/photo/my-images/197/95068012.jpg/
Old Feb 17, 2012 | 08:21 PM
  #250
That's a sure sign of a blown plenum. Need to address that soon.
