End-all Be-all plenum thread
I routed the wires as per the TSB.
I ran half a can of Sea foam through the brake booster line and put the rest into the gas tank. Smoked like crazy for a few minutes after the start up.
I cleared the CEL and went for a drive and my rough idle problem seems to be fixed! That stuff works wonders.
I'm going to run it for a while and see if I don't get a CEL again. If it pops back up I'll try the O2 sensor. Thanks for the tip on the NTK or Denso sensor!
Truck has 195,000KM on it (about 120K miles).
MY truck is a 98 5.2 l has 167,000 miles runs great uses no oil took off the tb 2 do the air horn fix looked down into the kegger and seen just a slight bit of oil is that normal? well thought id do the plenum fix on it anyhow huges whants 120.00 + bolts found one on e bay 4- 50.00 dollars same as huges + bolts and dont ! tell me its not the same its a peice of aluminium lazer cut looks like he sells a lot of them please no aruguments here
Johnnyjaw,
I bought the $50 plenum plate from e-bay. Works great - no complaints.
As far as the oil in yours, it may be bad PCV also. I am told that you should use on from dealer only. Others form parts stores reportedly don't work as well, although it has never been a problem for me on other vehicles. I bought dealer part anyway - only a couple of bucks.
They are on sale on ebay for 50 bucks and shipping.
http://www.ebay.com/itm/DODGE-JEEP-A...b9e037&vxp=mtr
I just finished the plenum last week. Used the ebay plate from the link above and it worked great. Everything lined up and fit perfectly. Much better choice than the other plates. Just my 2 cents worth.
I need to get mine done so she can quit drinking oil. Ill probably do that while the trans is out being rebuilt.
I have all the parts to do the plenum, but they've been laying in the backseat in a box for a few months. :/
