End-all Be-all plenum thread
#702
Attachment 17423
Attachment 17424
hey Patt, Here are the photos again. The location is right behind the distributor. The white line coming out the same location is a vacuum line. Anyways someone has got to be in the middle of a tear down that can help out. The truck a a 2001 1500 quad cab 5.9L.
Thanks.
Attachment 17424
Thanks.
#704
The first post of this thread will inform you of the many happenings involving this issue. The most common effected parts are a failed cat, o2 sensors, cylinder #8 misfire leading to that # plug fouling and many will argue that it can lead a cracked head..etc.
#705
#706
Sounds like either you missed a ground (double check them all DO NOT OIL ANY, make sure they are clean and tight), the main wiring went bad due to being moved around a lot, or (as happened to here) a bad battery cable... Which if the main harness goes bad be prepared to have a bad PCM as it can fry it...
#708
i need help! i installed the hughes plenum kit about a month ago and when i pulled my tb off the other day to clean it i noticed oil pooling in the manifold....AGAIN! i know i did everything the manual said. bolts were installed in correct pattern at correct torque. only thing i didnt do was use blue loctite on the bolts and that was because it already had red loctite on them.
any suggestions before i yank the manifold off and use it for target practice?
