overheating and radiator under vacuum?
Old 04-10-2011, 10:09 PM
sullivanj04's Avatar
sullivanj04
sullivanj04 is offline
im going to get a new cap tommorow and when i get time do the t stat anywhay would a bad radiator cap cause it to run hot not over heat but run around the 200-230 range on the stock gauge?
Old 04-10-2011, 10:13 PM
ghost4321's Avatar
ghost4321
ghost4321 is offline
Originally Posted by charlie1935
It should still get water thru the bypass.
Yes, but very little.
Old 04-10-2011, 10:30 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
Possibly. But, an air pocket would certainly cause that, and the gurgling in the heater core you hear at startup.
Old 04-10-2011, 10:39 PM
sullivanj04
so i will get a new cap and burp the system in the morning and report back how long should I burp it for? thanks for your help
Old 04-10-2011, 11:14 PM
Mad_Scientist's Avatar
Mad_Scientist
Mad_Scientist is offline
Burp it for however long it takes to get all the air out of the system.
Old 04-11-2011, 12:09 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
I read on here it wasnt good to leave the truck idling for extended periods of time, so how are you supposed to burp the coolant system?
Old 04-11-2011, 12:25 AM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
LOL? Never heard that before... ever.
Old 04-11-2011, 12:36 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
I know I saw it on here but I can't find the post. SomethIng about the pump doesn't run in park? I figured if the motor was running the pump would be too. Just wondering.
Old 04-11-2011, 12:43 AM
Mad_Scientist
Realistically, burping will take somewhere around 30mins tops. I'm not sure where you picked up that idling for extended periods is bad, but that's not true.
Old 04-11-2011, 12:44 AM
pcfixerpro's Avatar
pcfixerpro
That would be the trans pump, not the water pump.
Quick Reply: overheating and radiator under vacuum?
