Major engine work ahead of me
Old 04-11-2011, 03:52 PM
Seth_787446's Avatar
Seth_787446
Seth_787446 is offline
Default Major engine work ahead of me
Ok, so I'm going to be replacing the oil pan gasket, rear main, and the front crank seal. I figured for an extra $25 I could put in a new oil pump as well since it will be right there once the pan is off.
Since I have a front crank leak I might as well replace the timing gears and chain for an extra $40 and that way I can put on a new timing seal and gasket, that way I can inspect my water pump for any leaks and throw a new gasket on it if it checks out ok.
If you have read my previous thread I mentioned that I have an exhaust manifold gasket leak so I'll be replacing those as well, now if I'm correct my truck doesn't have a donut gasket for the flange right?
I just checked my truck the other day and found out that my plenum plate is original so I bought the aluminum plate from hughes so I will be doing that as well as replacing the intake gaskets.
Might as well throw on some new valve cover gaskets right?
I also have a radiator leak so I might try to fix that on my own or just replace it, I know that it is the original so it's 13 years old and those things don't last too much longer than that.
Last but not least I am going to be replacing the transmission pan gasket and adjusting the bands.
If anyone has any ideas as to what else I should replace then please let me know, thanks!
Old 04-11-2011, 03:57 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
look into 02 Sensors as well probably about time for those, and if you are doing the plenum then its a perfect time to do that.
Also some plugs, wires, cap and rotor, and you should be golden.
Old 04-11-2011, 04:01 PM
Seth_787446
I will deffinately look into some 02 sensors, and new wires and cap and rotor, thanks!
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
There aren't any exhaust gaskets from the factory.
Old 04-11-2011, 04:19 PM
Mad_Scientist's Avatar
Mad_Scientist
Mad_Scientist is offline
That's a pretty good list you got there man, only thing I'd add is a little seafoam in the intake (to clean the valves and piston heads of carbon). After you do all this, it should run like new.
Keep us posted
Old 04-11-2011, 04:21 PM
Seth_787446
Speaking of SeaFoam, where can I get some? Where else should I put some besides the intake?
Old 04-11-2011, 04:23 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
If you're going this deep, why not just yank the engine and go through it from stem-to-stern?
Old 04-11-2011, 04:30 PM
Seth_787446
That's a good point, I dont have what is necessary (tool wise) for taking the engine out, but what else beside what I listed would you recommend?
Old 04-11-2011, 04:34 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Advance Auto, Napa, AutoZone, Walmart, Tractor Supply Company, O'Rielly...You get the jist.
I dont suggest drinking it.
Old 04-11-2011, 04:50 PM
Mad_Scientist
Wal-mart is cheapest in my experience. You can also dump a can in the gas tank to clean the fuel system somewhat.
It says it can be used in the oil to clean the crankcase as well... I wouldn't do it, something about adding a solvent to oil gets my paranoia riled up.
Quick Reply: Major engine work ahead of me
