Surging when coming to a stop
Old Apr 13, 2011 | 12:59 PM
W8 a minute's Avatar
W8 a minute
Default Surging when coming to a stop
My truck has an annoying habit of surging when coming to a slow stop. It doesn't do it during a hard or quick stop. I don't see the tach jump, nor do I feel anything in the brake pedal, but I can definitely feel the whole truck surging. Like someone is pushing the brake harder and releasing or the torque converter is dragging. No abs light, no check engine lights. New rotors, pads, drums, and shoes. I'm at a loss.
Old Apr 13, 2011 | 01:13 PM
drewactual's Avatar
drewactual
it could possibly be your transmission governor pressure transducer or solenoid- and what you are feeling is a shift into second gear..
Old Apr 13, 2011 | 01:22 PM
W8 a minute
Possibly, but its a pulsing, meaning it happens repeatedly while slowing down. A shift would only happen once, correct?
Old Apr 13, 2011 | 01:23 PM
drewactual's Avatar
drewactual
yup... you should be able to rule that out..
Old Apr 13, 2011 | 06:33 PM
dhvaughan's Avatar
dhvaughan
warped brake rotors ?
Old Apr 13, 2011 | 06:35 PM
More likely warped drums.
Old Apr 13, 2011 | 09:43 PM
dhvaughan's Avatar
dhvaughan
i just re-read his first post. sorry.
.......New rotors, pads, drums, and shoes......
as a transmission test, shift into neutral before stopping and see if it acts any different.
Old Apr 13, 2011 | 09:52 PM
Just because they are new, does not necessarily imply they aren't warped. It got to the point where I would cut new drums/rotors as a matter of policy, since I hated doing the same job twice, but only getting paid once....... Too many were warped right off the shelf.
Old Apr 13, 2011 | 11:21 PM
rl99dram's Avatar
rl99dram
I agree with the drums being screwed up, or you may have an internal hemerage in one of the rubber brake hoses. When you push brake pedal your pumping fluid to the caliper pistons, and when you realease the brake pedal all the brake fluid gets sucked back up. With a piece of rubber on the inside of the hose (over time it happens) it will flip up the rubber making it a one way check valve causing your vehicle to surge.
Old Apr 14, 2011 | 04:11 AM
TryMeImHard's Avatar
TryMeImHard
yeah i'd check rubber lines one of mine is bad and i live on a gravel street when i go to stop at end of street you can hear/see one tire locks right up doesn't do it on pavement but can deff feel it still
