What does a bad clockspring sound like?
Old Apr 15, 2011 | 02:30 AM
vikingdiesel's Avatar
vikingdiesel
Default What does a bad clockspring sound like?
I am pretty sure I have a bad clock spring, but NOT sure, it makes a binding up noise right on the steering wheel when I turn, are after market clock spring good if that is my problem?
Old Apr 15, 2011 | 05:09 AM
TryMeImHard's Avatar
TryMeImHard
does you horn or cruise work
Old Apr 15, 2011 | 09:29 AM
vikingdiesel
Yes, all those work
Old Apr 15, 2011 | 09:31 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Then chances are you don't have a bad clockspring.
Old Apr 15, 2011 | 09:41 AM
vikingdiesel
The noise I'm hearing is soooooooo annoying and its hard to explain, I'm going to have to make a vid
Old Apr 15, 2011 | 09:47 AM
dodge dude94
You sure you don't have a bushing binding in your steering column/shaft?
Old Apr 15, 2011 | 09:54 AM
vikingdiesel
How would I check for that, the bushing you guys are referring to is the ROCK SOLID bushing that everyone replaces with? The noise come right be the steering wheel, under the column next to the steering wheel
Old Apr 15, 2011 | 09:57 AM
dodge dude94
No the Rock Solid is the steering box reinforcement IIRC.
There are other bushings in the steering column and shaft there wear out though.
BTW...to be honest...I dunno.
Sorry.
Someone shall be here soon!
Old Apr 15, 2011 | 10:31 AM
Is it just the wheel itself rubbing on the plastic housing covers? Might wanna pull 'em off, and see if there is anything obvious. There IS a bearing under there somewhere..... (a couple of them as I recall....)
Old Apr 15, 2011 | 12:01 PM
Silver_Dodge's Avatar
Silver_Dodge
tick tock tick tock tick clunk tick crap tick @#$% tock
