Towing Question: ~5,000lbs
If your truck weighs 5900 you don't have much before you hit the GVWR of 6400lbs. With your plow on you must be real close.
My very heavy duty headache rack, truck tool box, and tools probably puts my extra loaded weight pretty close to yours so I guess the difference between a reg cab long bed and an extended cab short bed is about 400lbs. I also have 285/75/R16's but are mud tires and load range D.
They can because they are lighter. I don't have all that extra cab just empty box. That does not make up the difference in this case though as the extended cab is not 2900 lbs heavier than the reg cab. My truck with two occupants, tools and stuff weighs about 5500lbs so the truck might weight around 5100lbs with just a driver.
With my AAL my truck only squats 1-3 inches at most with a fullsize on the trailer (8000lbs as stated earlier) (depends on how far forward the truck is on the trailer).
Don't know if it actually works that way though......
Thanks guys. So I should be okay. I didn't look for it in the manual, I looked up specs online. My biggest worry was pulling my pig out of the lake at the ramp. It's not easy on the truck at all.
Anyway, planning on removing the check valve here in the next 2 weeks along with a couple other projects.
Also, I never tow with O.D. on.
on
When I had my '98 RCSB 5.9 4x4 I looked up towing capacity and found it was 7400# with the 3.92 gears. At the time, I had a good size house in middle Georgia with a few acres of land and was forever hauling heavy loads and pulling good size weight, up to and probably a bit over the rated capacity.
The bass boat I had at the time I bought the truck was a 17' with 120 HP engine and I found I actually had to re-adjust the bunks and front roller of the trailer to have the boat sit farther forward to increase the tongue weight to keep the relatively light boat/motor/trailer combo (about 2300 lbs. empty) from wanting to sway on the highway.
The boat I traded it in on in 1999 didn't have that problem, it was longer (20') and with the 175 HP motor it was a good bit heavier, somewhere in the 3000 lb. range.
Pulled that SOB up some of the nastiest, slickest red clay ramps you ever saw and never had a problem. Did have to use 4 Lo a time or two though...
