(help) 96 dodge ram 1500 4x4
Old Apr 26, 2011 | 11:42 PM
hawk ed's Avatar
hawk ed
Default (help) 96 dodge ram 1500 4x4
i have a 96 ram and it wont start,
checked the fuel pump it good and the relays
are good but the truck will crank but will not start
it just wont pump fuel,
i ran a jump wire to the pump and it runs that way but it acts like its missing and wants to stall a lot,
please what can i do?
Old Apr 27, 2011 | 08:01 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Apr 27, 2011 | 08:10 AM
thompson1986's Avatar
thompson1986
bad ground somewhere?
Old Apr 27, 2011 | 10:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
welcome to the site
You say it will not pump fuel. How are you sure? Do you have a fuel pressure gauge on the fuel rail checking the pressure to verify the pump or just assuming it isnt working because the truck isnt starting?
Old Apr 27, 2011 | 04:13 PM
hawk ed's Avatar
hawk ed
the fuel pump is working just not starting unless i run a jump wire to the pump
Old Apr 27, 2011 | 04:16 PM
Check the ASD relay as well. Just swap those two, with some other ones in the PDC, see what happens.
Old Apr 27, 2011 | 09:26 PM
hawk ed's Avatar
hawk ed
checked the asd relay and swiched it out too and still the same thing when i run the junp wire to the pump it runs but trys to cut off but its the only way to get it to run.
its just driving me crazy.
Old Apr 28, 2011 | 07:37 AM
Novarider's Avatar
Novarider
Bad fuel pump? If you jump it shouldn't it run like normal if its good?
Old Apr 28, 2011 | 11:23 AM
hawk ed's Avatar
hawk ed
i was thinking that what ever did not let it run with out the jump wire might be making it not want to run right, but maby ill have to check the pressure again
Old Apr 29, 2011 | 09:21 AM
hawk ed's Avatar
hawk ed
got pruessure and still the same thing
