need cam advice
Old 05-06-2011 | 11:45 AM
dodgeman2289's Avatar
dodgeman2289
Originally Posted by u-shoot-irak
If you don't mind a used one I have the cam out of 98 318. A friend of mine has everything to measure wear I am going to have its specs soon it is still in my truck but should be out within a couple of days as long as i have time to get out there. I only have tranny bolts and exaust to remove before yanking out the engine. And one stupid motor mount bolt that will be manhandled today
Ya just let me knw
  #22
Old 05-06-2011 | 11:51 AM
97tn4x4's Avatar
97tn4x4
I believe as long as it's in one of the pipes you should be fine.
  #23
Old 05-06-2011 | 12:00 PM
u-shoot-irak's Avatar
u-shoot-irak
That's what i figured but not a major worry right now. I keep thinking of things as I go. I'm sure other things will pop up. All my linkage to transfer case looks pretty nasty also. MORE MONEY.
  #24
Old 05-06-2011 | 12:11 PM
97tn4x4's Avatar
97tn4x4
It adds up quick I've put right at 5k in mine since the end of February.
  #25
Old 05-06-2011 | 04:03 PM
u-shoot-irak
says u can't recieve message but i will post this site or private me ur email
  #26
Old 05-06-2011 | 06:48 PM
aim4squirrels's Avatar
aim4squirrels
I think he's just using a 360 magnum block, in favor of the 98 318. It should be a direct swap, save for the harmonic balancer and the flex plate. 360's are externally balanced, 318's are internally balanced so you ned a harmonic damper and flex plate from a 360 donor.
  #27
Old 05-06-2011 | 06:49 PM
aim4squirrels
Oh yes, and you'll ned a tuner for more fuel delivery for the larger cubes.
  #28
Old 05-06-2011 | 06:52 PM
97tn4x4's Avatar
97tn4x4
New TC also.
  #29
Old 05-06-2011 | 07:11 PM
aim4squirrels
Is the torque converter weighted? I thought it was only the damper and flex plate? Never seen a 360 tc to know...
  #30
Old 05-06-2011 | 10:54 PM
97tn4x4's Avatar
97tn4x4
Yep theyre weighted, seen quite a few lol. I'm not remembering exactly which one but either the 318 or 360 the flex plate is only drilled to fit the TC one way.
Quick Reply: need cam advice
