95 1500 4x4 keeping me stranded!
#31
If you can hear the pump running, but still don't get pressure, bad pump, or, a blockage in the line somewhere.
If you don't hear the pump running, need to find out why. You could try using a jumper wire in place of the relay, to see if the pump runs or not, and if you can get pressure that way. Have you tried swapping relays around?
#33
#35
well whats really weird now is when i took off the bed and then tried and cranked it the fuel pump primed and the engine ran perfectly. It died once when we walked inside. I made sure everything was connected and it fires up all the time now. Im going to put the bed back on and see if it was pinching a line or something!
