Found broken snap ring in tranny pan
Old May 12, 2011 | 08:47 AM
Choda's Avatar
Choda
Angry Found broken snap ring in tranny pan
Flushing the system last night and dropped the pan. Broken snap ring was in the pan about 4 inches long. wtf
Old May 12, 2011 | 08:50 AM
97tn4x4's Avatar
97tn4x4
Got a pic?
Old May 12, 2011 | 10:36 AM
J415's Avatar
J415
9 times out of 10, it's gonna be a snap ring that goes in the OD case. There notorious for breaking.
Old May 12, 2011 | 11:25 AM
Dycrow27's Avatar
Dycrow27
I have got the same thing i think. It is like part of a circle about a 1/4'' thick i'm in school now but when i get home. Ill take a picture of it. And post up here.
Old May 12, 2011 | 02:10 PM
aim4squirrels's Avatar
aim4squirrels
That snap ring helps with proper OD engagement, sooner or later you'll have issues with dropping out of OD for no apparent reason, or not properly shifting into OD. For now, I'd lockout OD to prevent further damage.
Take it to a shop and have them replace just that ring, not do a full rebuild. They should be able to pull the OD unit off the trans without dropping the whole unit, IIRC. Do it sooner rather than later, or more damage may result from sloppy engagement or falling out of OD which will cost the price of a rebuild.
Old May 12, 2011 | 06:21 PM
Adobedude's Avatar
Adobedude
Every 46RE ever made either has, or will have parts of that snap ring in the tranny pan.
Old May 12, 2011 | 09:44 PM
Dycrow27's Avatar
Dycrow27
This is what i found when changing the transmission fluid. The thick plastic one was in the transmission filter and the thin metal was found attached to the magnet on the pan. I dont know how to just post the picture not in a attachment sorry.
Old May 12, 2011 | 09:45 PM
O/D unit needs to come off, and that snap ring needs replaced. Otherwise, its as Aim says..... complete rebuild will soon be in your future.
Old May 12, 2011 | 09:54 PM
Dycrow27's Avatar
Dycrow27
Is that advice for me haha? Because i have no clue what those little metal things are. I guess if it is then there the snap ring.
Old May 12, 2011 | 10:01 PM
Yep, that'd be you.
