The front axle CAD
Old May 12, 2011 | 06:44 PM
AceWyatt's Avatar
AceWyatt
Default The front axle CAD
hey guys, curious if i can get some info here, my 4x4 seems to engage and disengage when it wants to when im on the trail and left me super stuck in a spot where i shouldnt have gotten stuck at all the other day. heres my symptoms : my 4x4 light doesnt come on when i shift into 4x4, 4x4 works in both 4 low and high but sometimes cuts out leaving me in 2 wheel, is there a fix for this? should i run new rubber lines and cut the steel ones out? do i replace the whole vaccum motor in the axle? HELP !!! i wanna go muddin!!!
Old May 12, 2011 | 07:02 PM
97tn4x4's Avatar
97tn4x4
I'd leave the steel lines cause they're stronger just check for any holes. The switch on top of the transfer case might be going bad but I think normally they just go out.
Old May 12, 2011 | 07:18 PM
AceWyatt's Avatar
AceWyatt
so maybe the CAD on the axle should be replaced? or replace the rubber lines at least?
Old May 12, 2011 | 09:42 PM
Don't replace anything blind. Find out what the problem is. Verify that you get vacuum on the lines at the cad for both 2, and 4 wd. Take it from there.
Old May 12, 2011 | 11:55 PM
AceWyatt's Avatar
AceWyatt
what would be the easiest way of checking for leaks? i put it in 4 wheel while it was running, pulled the vac plug off and only the right hole was blowing air...or maybe it was sucking...cant remember but only 1 hole was working. do both holes blow or suck air?
Old May 13, 2011 | 12:05 AM
97tn4x4's Avatar
97tn4x4
I believe you have vacuum in one in 4w and in 2w the other. Not real sure, I wasn't gonna mess with it and bought a posi lok
Old May 13, 2011 | 12:59 AM
AceWyatt's Avatar
AceWyatt
yeah i looked into the cable system, it looks pretty easy to install and almost failsafe. might go that route
Old May 13, 2011 | 01:14 AM
97tn4x4's Avatar
97tn4x4
It's a breeze to install. Took maybe an hour and as long as you don't melt the cable it'll last for a long time. It's actually really cool cause you have 2w low with the kit lol.
Old May 13, 2011 | 11:16 PM
AceWyatt's Avatar
AceWyatt
2 wheel low?? how does THAT work? hell i wonder if im in 2 wheel low now cuz my acceleration seems so low geared.... like im a slow **** off the line lol
Old May 14, 2011 | 12:47 AM
UnregisteredUser's Avatar
UnregisteredUser
Without the transfer case controlling the CAD, you can just shift into 4L with the CAD disengaged -- bingo, 2L. It's useful, but it makes it easy to shred rear diffs, too.
