Weird smoke
Old May 24, 2011 | 07:42 PM
CappinHoff's Avatar
CappinHoff
Default Weird smoke
I noticed today out of the two center vents a very faint smoke. It has no smell. Once I turn on the heat or air it goes away. It seems to only happen when not driving. I doesn't happen all the time.
Any ideas?
Old May 24, 2011 | 07:44 PM
Does your A/C still work? Sorta sounds like a small refrigerant leak in the evap core.
Old May 24, 2011 | 07:47 PM
CappinHoff's Avatar
CappinHoff
A/C works but it needs charged.
Old May 24, 2011 | 07:53 PM
That's kinda suspicious...... I would say leak check it with dye, but, not like you can even pretend to see the evap core......
Old May 24, 2011 | 08:36 PM
UnregisteredUser's Avatar
UnregisteredUser
With UV dye he wouldn't have to -- just hold the black light to the vapor coming out the vents.
Old May 24, 2011 | 09:54 PM
Sheriff420's Avatar
Sheriff420
Before my heater core got really bad and started fogging the windows it would let out a little puff of steam from the two center vents when I first turned on the air.
Old May 24, 2011 | 11:20 PM
CappinHoff's Avatar
CappinHoff
It does it with the heat and air off nothing on but the truck. I think it's the heater core as I get a film any time I run the vents.
Old May 24, 2011 | 11:46 PM
Sheriff420's Avatar
Sheriff420
Yep, that's the heater core.
Don't put it off until it gets cold like I did when mine was leaking. Removing the dash isn't too much fun when you can't feel your digits.
Old May 25, 2011 | 09:53 PM
CappinHoff's Avatar
CappinHoff
I plan on doing it before summer gets over.
