Leaf Spring Conversion With Pictures
Old Jul 24, 2011 | 11:46 AM
  #81
sk8erdude's Avatar
sk8erdude
it just misses the leaf, i used washers to get it up high enough. does anyone make a knuckle adapter? i thought they were all for D60s? i thought about getting a drop pitman arm and bending the tube a bit...
Old Jul 24, 2011 | 12:59 PM
  #82
You are planning on doing a D60 swap at some point anyway aren't you? If that is going to be within the next year..... I would just leave it as is, and then address it if it is still a problem with the bigger axles.
Old Aug 1, 2011 | 05:51 PM
  #83
sk8erdude's Avatar
sk8erdude
so finally got to drive it a bit. kinda... still dont have gears, but if i leave OD off it runs the same rpms down the road, lol! and im putting on the front shocks tonight. from what little ive driven it, its takes all my attention to drive it. if i dont hang on to the steering wheel hard enough it jerks on every bump on the road even with the stabilizer. but its not as bad as i thought it would be and getting the front shocks on will help...
Size:  53.9 KBit still sits one inch higher in the front, gotta get some blocks...
Old Aug 1, 2011 | 06:39 PM
  #84
aim4squirrels's Avatar
aim4squirrels
Might not need the blocks, all that front end engine weight should flatten those springs pretty quickly I'd think.
If you put blocks in the back, you might be nose diving in 3 months.
Old Aug 1, 2011 | 07:01 PM
  #85
redheadhunter21's Avatar
redheadhunter21
looks like you need some new side steps...lol
Old Aug 1, 2011 | 11:14 PM
  #86
sk8erdude's Avatar
sk8erdude
i think they might have saged just a little already...
Old Aug 2, 2011 | 12:19 AM
  #87
97tn4x4's Avatar
97tn4x4
That thing is a beast lol.
Old Aug 2, 2011 | 10:16 AM
  #88
Kwdog75's Avatar
Kwdog75
Your truck wanders because of your front end setup. You should make your front perches shorter and run a shorter shackle too. Install a set of front springs with a bigger arc and that will take care of the wandering.
Or... run a custom four link with coilovers.
Old Aug 3, 2011 | 01:32 PM
  #89
sk8erdude's Avatar
sk8erdude
uhh, never said it wanders... and if it did i would use a track bar to fix it. but 4 link would be sweet!
and anyways the shorter the leafs are the better, theres less leverage from side to side. the length of my front perches has nothing to do with it, they dont move the longer the better, as long as they are beefy enough. but i should have gone with a shorter shackle...
Old Aug 4, 2011 | 03:51 PM
  #90
Kwdog75's Avatar
Kwdog75
How does it corner?
