Air Cleaner Questions
Old Jun 1, 2011 | 12:25 PM
loew2191's Avatar
loew2191
my one question is will a 14x4 or 14x5 fit under the hood of ours?
Old Jun 1, 2011 | 12:28 PM
Too tall. The air cleaner is going to sit back underneath the cowl, so three inches is about all you are going to get there.
Old Jun 1, 2011 | 12:29 PM
RamSport97's Avatar
RamSport97
Not without a body lift. A 3" tall filter is a snug fit as it is with a .5" drop base.
No need for a 4 to 5" tall filter anyway, your truck will never see use of it.
If a Shelby Cobra with a 427 big block can make use of a 10x2, then your 360 small block will be just fine with a 14x3
Old Jun 1, 2011 | 07:52 PM
sprntpshr's Avatar
sprntpshr
If a Shelby Cobra with a 427 big block can make use of a 10x2, then your 360 small block will be just fine with a 14x3 [/quote]
Run a 467 Big block with a 10" x 3" with a sock, 6800 rpm, 785 HP on the dyno with no problems on dirt tracks. It was however isolated from all engine heat and drew air from a scoop in the hood.
On the trucks, going to go back to stock type setup B/C for my uses the open filter sucks up too much dirt and engine heat in the summer and water and snow/salt slush in the winter. Just my experience.
Old Jun 1, 2011 | 08:51 PM
dodgeman2289's Avatar
dodgeman2289
i got spectre its nice i get alot of air. can hear the sucking under the hood in the cab. its all about wut you like and wut you want. i like the 14x3 but in florida to much hot air. so i went with spectre wityh the heat shield box. 94 from amazon with free shipping
