hubs not engaging?!?!
Old Jun 14, 2011 | 03:27 PM
mj23polaris's Avatar
mj23polaris
Default hubs not engaging?!?!
transfer case will go into lo and hi, but hubs are not locking.
what are some things i should be looking at?
01 2500 gas
Old Jun 14, 2011 | 04:11 PM
Front axle central disconnect is all vacuum powered, with the engine running, see if you have vacuum at the front axle. (there are two lines, one should have vacuum in 2wd, the other should have vacuum in 4wd.) If you don't have vacuum there, work you way thru the system till you find out where it went.
Old Jun 14, 2011 | 05:00 PM
mj23polaris
are you talking about the 2 lines that run side by side into a saucer lookin thing on the CAD
Old Jun 14, 2011 | 07:08 PM
That would be them.
Old Jun 14, 2011 | 08:20 PM
dhvaughan's Avatar
dhvaughan
read this. http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Jun 14, 2011 | 09:28 PM
mj23polaris
should i be able to move/rotate the vacum shift motor? the little saucer thing?
Old Jun 14, 2011 | 09:39 PM
dhvaughan's Avatar
dhvaughan
yes, i think it will sort of rotate back and forth some. its just a vacuum diaphragm, attached to a shaft with the fork and collar attached.
the best way to get familiar with it and troubleshoot it, is to put the truck up on 4 jack stands and play with it. notice how right front (passenger) free wheels in 2wd, and locks up with the front drive shaft in 4wd. also since you have an open diff, when spinning tires by hand - one will turn backwards. you'll have to have the engine running in order to get a shift. but when you turn the engine off it'll remain in that 2wd or 4wd position.
Old Jun 15, 2011 | 04:13 PM
mj23polaris
i got vac out of the left hose on the motor, im guess its the whole motor, think im jus gonna get posi lock for it, id love to get a free spin kit and just eliminate the cad and unit bearings but i dont have 2k to through out there haha
Old Jun 15, 2011 | 05:09 PM
Does the vacuum switch when you change from 2 to 4 wheel drive? (T-case lever.)
Old Jun 15, 2011 | 06:25 PM
mj23polaris
no same one
