newbie from Alabama
Old Jun 20, 2011 | 01:02 AM
Connector will be on the outside.
There is a factory service manual available for download in the faq section, the procedure for band adjustment will be detailed in there. (with PICS!! )
Have you cleaned your throttle body, especially, the IAC passages?
Old Jun 20, 2011 | 08:26 AM
aim4squirrels's Avatar
aim4squirrels
FSM:
http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
Old Jun 20, 2011 | 01:48 PM
Carl2206's Avatar
Carl2206
Originally Posted by aim4squirrels
Welcome to the site.
evap purge is a leak in the gasoline vapor trapping system, and could be a simple as a bad gas cap. Also check the passenger side engine bay for a circular solenoid that looks like it's got 4 or 5 rubber tubes coming from it. Check those tubes cracks or leaks. Then check the large tube that feeds into the front of the throttle body for cracks.
Transmissions are the weak link of this particular generation of truck. Your symptoms sound like a trans, on it's way out. You can try a band adjustment to see if the band is just so loose it won't grab the drum, or replacing the governor solenoid and sensor, but it's likely you could just be throwing good money away. I'd take it to a trustworthy shop and get a diagnosis.
HeyYou ninjaed me on the rest. He's an epic post *****, but he knows his ****.
So TRUE.
Old Jun 20, 2011 | 03:24 PM
Mpi360's Avatar
Mpi360
THX for the link to the FSM AND his website. Thats a BA ram.
Old Jun 20, 2011 | 03:35 PM
aim4squirrels
Yes, yes it is.
Old Jun 20, 2011 | 10:09 PM
ClubCab5.9's Avatar
ClubCab5.9
Originally Posted by lastrights
Sound like a sensor .. they can be wacky on these trucks .. for some reason I see a lot of 01 rams with tranny problems . Change tranny fluid it should be a good ruby red color . Post some pics and welcome ..there will be guys with better advise
I agree lets see some pics.
Old Jun 20, 2011 | 10:21 PM
aim4squirrels
And so it begins, another female run off the DF.
Old Jun 20, 2011 | 10:30 PM
ClubCab5.9's Avatar
ClubCab5.9
How does asking for truck **** running someone off? Being male or female?
Old Jun 20, 2011 | 10:55 PM
aim4squirrels
Sorry, thought you were going the horn-dog route with the pic requests.
Old Jun 21, 2011 | 12:08 AM
Sheriff420's Avatar
Sheriff420
That thing to the right of my hand is the evap purge solenoid (what aim is talking about). Put your finger on it while the truck is running, if it's working then it will be clicking and you'll feel it.
