torque converter stall range
Old Jun 20, 2011 | 08:12 PM
Buck Slayer's Avatar
Buck Slayer
Originally Posted by aim4squirrels
Best guesses I've seen online are 1800-1900 rpms.
I have been told that the stock tc is very sloppy, and a good aftermarket one even at the stock stall would see a nice improvement off the line.
I have also heard this, hence the reason I'd like to upgrade it. Not to mention its not terribly expensive.
Old Jun 20, 2011 | 08:14 PM
Don't go cheap..... or you will end up with the same issues. An 80 dollar torque converter is NOT an upgrade.....
Old Jun 20, 2011 | 08:27 PM
Buck Slayer
Yeah, 1600-1900 RPM sounds like it would be a good idea for ya.
If I went just a hair higher what would that do, like in the low 2xxx's.
Old Jun 20, 2011 | 08:36 PM
Buck Slayer
Haha well no, I don't believe in that! One thing I don't go cheap on is my truck! But by not overly expensive I mean less than 500ish. I'd say one in that price range would be alright huh?
Old Jun 20, 2011 | 09:21 PM
aim4squirrels's Avatar
aim4squirrels
Yes,
Wayne at APS Percision makes good torque converters, as does Martin Saine, and I've also heard good things about the PATC converter.
Be careful on overdoing your stall speed. Higher stall= more heat for the trans to deal with. You need to match the stall to your engine's power band. A good rule of thumb is to go with a stall that is 400-500rpms lower than the start of the power curve. If you haven't modified your truck that much, stock stall is probably optimal. If you've done some more extensive modifications, and we're talking heads and cam here, you really need to dyno your truck to find out where that sweet spot starts.
Keep in mind too, that a heavy truck tends to "stall" higher than in a light race car, so a 2400rpm stall converter can act more like a 2600 or even 2800rpm converter.
honestly, if you have your mind set on really modding your rig, a converter should be one of the last mods you do, to avoid having to do it twice.
Old Jun 20, 2011 | 10:18 PM
Buck Slayer
Yes,
Yes that indeed does make sense. I'm looking at either turboing or supercharging my truck, 1.7 rr's, and probably a new intake manifold. Also maybe a shift kit. Also a tranny, oil, and powersteering cooler. I was going to go with dual electric fans but I was worried how they would handle with the towing. And after everythings done I guess that's when I should add the tc.
Old Jun 20, 2011 | 11:37 PM
We have several folks that tow here, with electric fans, and they LOVE them, as they get air flow when they are backing up their heavy trailers. If you get mean enough fans, it won't be an issue.
Old Jun 21, 2011 | 02:01 AM
Buck Slayer
wait what?
Old Jun 21, 2011 | 02:14 AM
J415's Avatar
J415
Originally Posted by Buck Slayer
wait what?
He means when your going in reverse while towing...with e fans, air will continually cool the rad.
Old Jun 21, 2011 | 01:01 PM
Buck Slayer
Why would you go in reverse while towing?
