torque converter stall range
Old Jun 21, 2011 | 01:06 PM
  #21
aim4squirrels's Avatar
aim4squirrels
To back the load in somewhere. As on a trailer, boat, RV, Etc.
Some folks got long driveways.
Old Jun 21, 2011 | 01:07 PM
  #22
aim4squirrels
Double post ,FTW!!!
Old Jun 21, 2011 | 01:09 PM
  #23
Backing your trailer into a spot, or some such.
Old Jun 21, 2011 | 01:31 PM
  #24
Buck Slayer's Avatar
Buck Slayer
Haha ummmm ok. So the dual efans would be sufficient enough for use while towing?
Old Jun 21, 2011 | 01:45 PM
  #25
if you get mean enough fans.
Old Jun 21, 2011 | 02:09 PM
  #26
drewactual's Avatar
drewactual
I run twin 16" fans purchased off eBay for >$20 each.. One pushes, one pulls.. They are offset on my radiator, and I retained the factory shroud.
they are rated at 2750cfm (the puller) and 2400cfm (the pusher), as they don't push as much as they can pull due to simple geometry.. anyway:
I have about $100 in wiring, relays, fuses, and controllers.. I went fairly cheap on the fans themselves because I thought them (and still do to a lesser degree now though) to be the expendable part of the rig.. they are holding up more than fine though.
I didn't do my upgrade for performance purposes, I did it for one reason only: backing a #7000 boat up a long drive into the barn.. the only time i've come close to overheating on a healthy engine is doing something like this. It absolutely has the ***** to do what I need it to now, and the temp gauge doesn't budge. Add to that the nice little bonus of likely 20-30# of torque right off the line (right where you need it while towing) and this is one of my favorite mod's..
I kept my clutch fan in my tool box 'just in case'.. I've never needed it once..
Last week, in nearing 100* weather I was stuck in traffic.. I can recall this happening in the past.. i'd watch my gauge climb, and ultimately resort to turning on the heater full blast to attempt to dissipate heat better.. well, I sat there last week in traffic for about half an hour- foot off brake roll, jump to 15-25mph, stomp on brake pedal, sit- with my a/c kicking and a eagle eye on the gauge.. it didn't budge..
I pulled a trailer with a car on it a few weeks ago about 20 miles- once i reached operating temps (and where I have the controller set) it never budged.. A matter of fact, the fans are set to such a way that they kick on for about 5 seconds, and off for about 20 or so even in the worst conditions..
do the efan dude.. you'll appreciate it for certain.
Old Jun 21, 2011 | 02:33 PM
  #27
Buck Slayer
So what you're telling me is a don't have to buy one of these expensive dual setup kits that run 4 and 5 hundred bucks? Although jegs does have one for about 210 minus any brackets and wiring rated for 2600 cfm each and there 12".
Old Jun 21, 2011 | 03:13 PM
  #28
drewactual's Avatar
drewactual
helz no.. I'd put my system up against the effectiveness of one of those any day, and i have about $150 in it.. I could have much less if I wasn't so **** about the wiring, soldering, shielding, relays, fuses and controllers.. I could have been out of it for about $70 or so..
Old Jun 21, 2011 | 03:15 PM
  #29
There is something to be said for being ****, when it comes to your cooling system though..... Better to be over designed, than under designed.
Old Jun 21, 2011 | 03:43 PM
  #30
Buck Slayer
i completely agree!
