Mechanic in Sacramento, CA
Old Jun 29, 2011 | 05:15 PM
Cheesehead's Avatar
Cheesehead
Default Mechanic in Sacramento, CA
So I take my '01 Ram 1500 4WD in for front brakes. Then get a call saying they can't test drive it because it has excessive smoke coming out of the tail pipe!!
It looks like I need a mechanic in the Sacramento area any ideas?
5.9 with 141k on it.
Jeff
Old Jun 29, 2011 | 05:34 PM
Was it smoking when you brought it in?
Old Jun 29, 2011 | 05:41 PM
Cheesehead's Avatar
Cheesehead
Nope!!
Old Jun 29, 2011 | 05:49 PM
redheadhunter21's Avatar
redheadhunter21
Then I would be making them fix it, if they already did the brakes.
If it was smoking when they went to put it on the lift they should have called then
Old Jun 29, 2011 | 05:58 PM
Cheesehead's Avatar
Cheesehead
going to have a word with them now. I have not seen it yet. I was just trying to be a little proactive. I'm gonna tell them. It wasn't smoking when I brought it in!
Old Jun 29, 2011 | 06:28 PM
bosanci28's Avatar
bosanci28
hmm,thats wird,
everything was working fine,and now is smoking?
wow,thats not good,normally at first key if something wrong ,they should stop and call you,even before they do anything!...
Old Jun 29, 2011 | 07:56 PM
Cheesehead's Avatar
Cheesehead
Got typical we did the brakes had nothing to do with the motor. They didnt take it for a test because u could hear the metal rubbing.
So first thing I checked the oil, looks normal, started it have very severe smoke out the tailpipe shut it down.
Now what.
Old Jun 29, 2011 | 07:57 PM
Still got good oil pressure? Hows your plenum? What color smoke?
Old Jun 29, 2011 | 08:04 PM
Cheesehead's Avatar
Cheesehead
Pressure on idiot gauge came up
Plenum?
White/gray smoke
Didnt let it run long. Would appreciate any assistance.
Current plan is to get it tomorrow morning and have it towed
Old Jun 29, 2011 | 08:05 PM
Ruh roh roerge. You oil looked ok?
That is the sign of a blown headgasket.........
