Vacuum line issue
Old Jul 5, 2011 | 03:31 PM
Originally Posted by zman17
OK? so I worded that wrong. I know the years between cable and electric motor for the blend door. Which I think you may know that from me? (cable adjustment per 98 FSM). Point is, the blend door might not be working. Hence the reason I asked if the compressor is running.
True that. And yes, I DID learn that one from you.
Old Jul 6, 2011 | 09:55 PM
tandc92405's Avatar
tandc92405
The compressor does not run. So I guess I have more issues them just a vacuum line.
Old Jul 6, 2011 | 10:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If the compressor does not run you have to find out why obviously. Could be a number of things. Like it or the clutch is no good, low or no r134a due to leak, fuse or relay, etc.....
