The right way would be to have an X or H pipe, you install the bung in the center. If you don't have that, then you are stuck to putting it in one side only.
Well while were discussing true duals, I don't like the idea of seeing 2 pipes out the back bc everyone who gets aftermarket exhaust gets dual out the back. Would it be ok, if I ran true duals that turned and joined into one pipe right before the side and was a single side exit? What do yall think?
