Help me
So.... I bought the truck. (95 dodge ram 1500 slt reg cab short box with a 5.9l magum v8 in it...
Fuel pump not wanting to kick in now 2 weeks later... Any ideas?
getting a new windshield free of charge which is nice...
The truck makes a squeelin noise when accellerating any time...Any idea whats wrong???
This truck idles around 600rpms or less and oil light comes on... Any idea whats wrong?
This truck is awesome, i was a ford truck guy didnt have enough money to by a ranger so i bought the dodge... all my friends were like wtf. But this truck is amazin!
swap the horn and fuel pump relay and try it, if its a no go replace it, its about 200+ for the pump.
check the serpentine belt for cracks or any kind of wear, replace it and maybe look into a new tensioner.
what does your oil pressure look like? how many miles are on the truck? its possible your crank bearings may need replaced but thats just a guess.
WEll has 101694 miles on the truck. Serpent belt is new belt tensioner is tight. its only squeelin when i have the trucking going out on road moving... Id be super depressed if it was cam bearing for noise but doing think so. Someone said it might be a air leak on transmission or something idk... have no idea. How would you switch horn and fuel pump relay?
O and oil pressure drops to almost nothing when it is idling or in park... might be gauge. oil is full and its clean will change it in 2 weeks because i will have a paycheck comin and not have to pay for truck if its fuel pump there replacin it not me
i had a bronco with the same oil pressure thing going on but the day i noticed it i was on the way to the dealer to trade it in so i never had to deal with it lol they paid wayyyyyyy too much for that pos.
"swap the horn and fuel pump relay and try it, if its a no go replace it" how you do that?
Im confused
Im confused
Trending Topics
Relays are in the PDC (power distribution center) under the hood, right behind the battery. Relays/fuses are labeled on the underside of the cover. Relays just pull right out. Swap fuel pump relay, and horn relay. See if the truck runs.
