My dodge restoration!
Old Jul 24, 2011 | 09:24 PM
  #21
dogbosser14's Avatar
dogbosser14
Windshield finaly in did a good job just very slow. I know for a fact my plenum is bad and has a vacum leak there...
When i get that replaced i will have the mechanics flush my tranny fluid, redo oil, oil filter, new antifreeze ect ect...
I am workin 14hrs/13hrs a day not to much time to do anything but sleep and work now. poor truck
Old Jul 24, 2011 | 09:32 PM
  #22
Don't flush the trans. Just change the fluid that comes out when you go for the filter.
Old Jul 25, 2011 | 02:53 AM
  #23
dogbosser14
WEll my friend told me to flush it because i dont know when they last changed it. and he told me to then change it every 3 oil changes he is a master mechanic that works on high end audi's lol he hates workin on vehicles when he gets home but he is a smart tool to have when questions come up! I have no idea when last owner changed the tranny fluid thats why i want it flushed. I have a very good idea what to do on the air brushing that i will hire someone to do around here.
Old Jul 25, 2011 | 09:45 AM
  #24
Not knowing the last time is was changed is a good reason NOT to flush it. If you have the correct equipment, that does NOT flow the trans fluid backwards.... to clean it out, it might be ok. But, doing a reverse flow flush is a good way to kill your trans.
These are not high end trucks, and do not get the maintenance that some of the more expensive cars do.....
Old Jul 26, 2011 | 11:29 PM
  #25
dogbosser14
Yea i know but i am having a mechanic do all the work and everything they have top end equipment there so it should be fine if it aint and it kills tranny they will buy me a new one and replace it
Old Jul 27, 2011 | 12:18 AM
  #26
stangs13's Avatar
stangs13
Master tech with a fancy flush machine, or a 17 year old with a garden hose...either way on a 15 year old tempermental tranny, chances are flushing it you will get problems..good luck with the truck though, the more things you do to it to make it better, the more satisfaction you get!
Old Jul 31, 2011 | 11:46 PM
  #27
dogbosser14
its 130$s at napa. so yea idk if something goes wrong ill go back there and bitch lol Gettin new parts ordered out of next pay check...
to get:
http://www.hughesengines.com/Index/p...4&partid=26190
http://www.hughesengines.com/Index/p...4&partid=21981
(is this a good thing to get or no?)
http://www.hughesengines.com/Index/p...d&partid=24265
http://www.hughesengines.com/Index/p...=&partid=23360
There goes my pay check to that and havin mechanic put em on lol
Old Aug 1, 2011 | 11:36 AM
  #28
Yeah, the tune up kit is pretty popular.
Old Aug 10, 2011 | 01:32 AM
  #29
dogbosser14
Default wellll...
Would a failing fuel pressure regulator be a cause of hard starting? it always starts up on 2nd try after cranking it over... starter good, alternator good, only thing i can think of is fuel system.... Any ideas?
Oh i have not had the chance to order parts nor work on my truck working 14hr days really kills a my want to work on my truck, lol havent had a day off in almost 3 weeks....
Old Aug 10, 2011 | 08:40 AM
  #30
zman17's Avatar
zman17
Retired Moderator - RIP
Yes it can. If you have a fuel pressure tester hook it up, start motor, turn motor off and see how long the system holds pressure.
