My dodge restoration!
Old Aug 25, 2011 | 10:12 PM
  #51
Try pulling the heat shields off to make getting to them easier.
Old Aug 27, 2011 | 11:59 PM
  #52
dogbosser14's Avatar
dogbosser14
U can take of the sheild around the spark plug? Didnt know u could hoe could u do that?
Old Aug 28, 2011 | 01:30 AM
  #53
merc225hp's Avatar
merc225hp
Vise grips, pull, wiggle, twist. They can be a pita to get out.
Old Aug 30, 2011 | 08:45 PM
  #54
dogbosser14
Well update, schools starting next tuesday and i am going to be doing things to my truck since i have all of my credits... Will be doing my own exhaust i think. should be alot cheaper. any idea what steel to use? or if anything i could coat it with so it wouldnt rust? and well i got bad news after a check up from J&D service... well i have a bad fuel pump that is causing fuel to drain back causing long and excessive cranking time... well going to go see if they have a fuel tank and pump at Bud jones junk yard lil far away but o well... going to see my friend said they sold em one for his ford for 45$s...
Old Aug 31, 2011 | 07:29 AM
  #55
zman17's Avatar
zman17
Retired Moderator - RIP
The pump isn't bad, the pressure regulator on top of it is. They are available from Autozone, $55
Old Aug 31, 2011 | 11:39 AM
  #56
dogbosser14
See i was thinking that to but he said it wasnt. I had it narrowed down to fuel pump or pressure regulator...
Old Sep 5, 2011 | 08:33 AM
  #57
dogbosser14
Well schools tomorrow. I need ideas what to do and replace on my truck. Not spendy spendy or major overhaul something i can replace in 2hrs. Whats some ideas? i need some ideas it would be really helpful my truck has 105k miles on it everything stock. but have to go get gas and work a 12hr shift so i will look on here later. Thanks again
Robert Powell
Old Sep 5, 2011 | 08:58 AM
  #58
Plenum?
Timing chain and gears?
(neither of those are two hour jobs though...)
Headers?
Y-pipe?
Fix the broke stuff?
Polish up the headlights? (they are yellowed, aren't they?)
Old Sep 6, 2011 | 12:35 AM
  #59
dogbosser14
Well headlights are yellowed and cracked(going to get aftermarket 1 piece headlights). Plenum i am going to do thats a must. then i will do exhaust... Headers i was thinkin eldobrok shorty headers...(Does anyone have them and like them?) And what do u mean "Y" pipe?
Just bought a chiltons repair manual for my truck yippee
Old Sep 6, 2011 | 08:29 AM
  #60
chadhager03's Avatar
chadhager03
The y pipe is after the headers and before the cat. It's a huge restriction on these trucks, according to this forum. From past reading I would suggest changing that first before the headers
