welded rear end
Old 07-20-2011, 03:13 PM
thompson1986's Avatar
thompson1986
thompson1986 is offline
Default welded rear end
i would like to know the pros and cons of welding a rear end i know nothign about it other than it makes both tires spin at the same rate, i plan to use the vehicle on the street
Old 07-20-2011, 03:33 PM
chadhager03's Avatar
chadhager03
chadhager03 is offline
Pros- you won't get stuck, you'll drift around every turn, and you'll do perfect burnouts.
Cons- you could snap your axle, you won't be able to turn very well without spinning your tires, and you'll eat the crap out of your tires. Not good for street driving.
Old 07-20-2011, 07:23 PM
sk8erdude's Avatar
sk8erdude
sk8erdude is offline
for a truck that is mostly on the street, not a good idea. if its a cheap play truck to go muddin in, then you could do it.
where in IL are you at?
Old 07-20-2011, 07:26 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
No go if a street driver, it would be one thing it if was only driven to and from the trails, or if it was a drag/fun truck where driveability is sidelined to performance
Old 07-20-2011, 08:27 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
no...
Old 07-20-2011, 11:14 PM
thompson1986
it is only driven to and from the trails, i live in Joliet IL and its not a truck its actually on a jeep but i dont feel like going on a jeep forum
Old 07-20-2011, 11:53 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Welded gears will suck on the street..... cornering will be interesting, on slippery stuff (wet streets....) your truck won't want to turn, it will want to continue going straight... There is a reason folks don't use spools on the street, which is effectively what you will have. Please don't do that.
Old 07-21-2011, 01:56 AM
redheadhunter21
If your only go to and from trails its not going to be to bad, it will take some time to get used to.
Another thing dont blast it around corners and you will be fine, bronco's with a welded rear end are fun as hell
Old 07-21-2011, 02:07 AM
FireDodge's Avatar
FireDodge
FireDodge is offline
My truck is my daily driver and I recently put the Lock-Right locker in it. It is surprisingly street friendly. Even when its wet outside it won't break loose around a corner if I drive like a normal person. But if I do give it some gas it becomes a 7000lb toy
Old 07-21-2011, 03:00 AM
candymancan's Avatar
candymancan
candymancan is offline
So question.. How do you check if your Limited slip is working right ? Im not sure if mine still works.. However when i turn sharp and floor the gas pedal my rear end does fish tail, and when making u-turns the rear does spin if i step on the gas hard.
I have all time 4wd tho not 2wd NP249
Quick Reply: welded rear end
