Truck very sluggish
Old Jul 20, 2011 | 10:11 PM
VinsBlackRam's Avatar
VinsBlackRam
Default Truck very sluggish
So my truck is realy sluggish. its not the plenum i already checked. does anyone kno what it could be? could it be a bad cat? or timing off? i replaced plugs, wires, cap rotor. HELP!!!
Old Jul 20, 2011 | 11:56 PM
Remove the pre-cat O2 sensor, see if it runs any better. Might also want to check fuel pressure.
Old Jul 21, 2011 | 09:59 AM
(texas-ram)325HP's Avatar
(texas-ram)325HP
Maybe the cat or the O2 sensor like Hey you said
Old Jul 21, 2011 | 11:18 AM
blackbeasst's Avatar
blackbeasst
just to get it out of the way, how did you check the plenum to know its ok?
Old Jul 21, 2011 | 01:33 PM
VinsBlackRam
like everyone else did lol check for pools of oil and what not
Old Jul 21, 2011 | 01:36 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Define "sluggish".
Old Jul 21, 2011 | 04:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
By just looking through the plates I assume? Or did you remove the TB ?
Old Jul 21, 2011 | 05:34 PM
jasonw's Avatar
jasonw
Site Moderator
The only true way to check the plenum is to remove the intake manifold and get a flash light down in there to see every single corner, nook, and cranny. Mine didn't look busted through the throttle body plates or with the the entire TB removed. However, when I did what I thought was going to be preventative maintenance, turns out I had about half a quart of oil in there, pooled where I couldn't see with it installed on the engine.
