Plenum fix...Am I missing anything?
Old Jul 23, 2011 | 11:36 PM
stnlycup's Avatar
stnlycup
Default Plenum fix...Am I missing anything?
Hey guys...mostly hang around and soak up all the knowledge here.....Need some input
99 4x4 360 cid..62000 miles...not a daily driver...Trailmaster leveling kit and 285 BFG tires..B&M deep tranny pan...
Oil was 2 quarts low when i changed the oil the last time(first time its been low at a change)gas milage dropped last fall/winter..only have driven 1-2k in the last yr...Dont think there are any problems with the cat...yet...not throwing any codes
I dont do much towing or hauling so thats not a concern
Swapped out the stock filter with a K@N and went with a 14x3 Edlebrock
Got a plenum plate off the bay for $57 and am going to be doing that in the next couple weeks...Im putting together a list of things to do when its torn down...here is my list
-Plenum fix
-waterpump..not sure if I want to get a high output pump just because...
-double roller timing set
-kegger mod
-180 deg thermostat
-autolite copper plugs (3923's???),accel cap and rotor
-wires?????not sure what brand....any input here???..thinkin bosch
-would like the Hughes 1.7 roller rocker upgrade,50mm throttle body and a cam....but thats more $$$ than I want to spend right now, so maybe later
-If I have the time..Im gonna remove the tranny check valve
-SCT tuner when im done
Dont need the best of everything....but not gonna go cheap either
Any input on brands or anything else i might need would be appreciated from the experts here...
Thanks in advance guys
Old Jul 24, 2011 | 12:01 AM
Would that be the harland sharp roller rockers? (they run around 300 for a set....)
Don't need a high flow water pump. Stock output works just fine.
Do the tranny check valve SOON. It can be done for under ten bucks, and may save you a 1500 dollar rebuild.... dirt cheap insurance.
Old Jul 24, 2011 | 12:10 AM
Mill Man's Avatar
Mill Man
you will for sure want to replace the hose that goes from the water pump to the intake without a doubt! it is cheap insurance that will prevent you from having to tear the front of the engine down again.
Old Jul 24, 2011 | 12:16 AM
stnlycup's Avatar
stnlycup
Oops..yeah harland sharps...lol...got lots of brands and such running through my head...
Guess maybe i shoulda done the check valve today instead of the air filter...maybe tomorrow
Noticed your from Adrian...Hello from Toledo
Old Jul 24, 2011 | 12:17 AM
Neighbors.
Howdy!
Old Jul 24, 2011 | 01:08 AM
DodgeRam10's Avatar
DodgeRam10
I went with the taylor thundervolt 8.2mm wires, seem to have good reviews and their just a hair thinner than msd and $30 cheaper. heres the site i got it from, seemed the cheapest. Also type " carcruise" in the coupon spot and youll get $10 off so its a good deal. they also sell the accel cap and rotor for cheaper than the auto stores.
http://www.streetsideauto.com/p/tayl...pping#MoreInfo
Old Jul 24, 2011 | 01:10 AM
DodgeRam10's Avatar
DodgeRam10
and that coupon expires on the 26th so id hurry if you decide to get em.
Old Jul 24, 2011 | 02:29 AM
redheadhunter21's Avatar
redheadhunter21
good choice on plugs
I got my wires/cap/rotor from summit, they sell a tuneup kit for $52 that includes
them all
Definantly get a bypass hose, and a pcv valve, while your at it you might want to change the valve cover gaskets too
Old Jul 24, 2011 | 07:19 AM
Carl2206's Avatar
Carl2206
be carefull if you remove the trans check valve you will get torque converter drain back.
Old Jul 24, 2011 | 10:52 AM
A small price to pay for having that valve out of there.
