96 Dodge ram overheated
Old Jul 25, 2011 | 11:12 PM
maconthenabb3@yahoo.com's Avatar
Default 96 Dodge ram overheated
I have a 96 dodge ram 2500 4wd v10 that over heated pretty bad. and now the truck will not start. does any one have any ideas on what could be wrong with the truck that i could check on so i can get it running again. please help out!
Old Jul 25, 2011 | 11:57 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. First, before anything else, please read this.
I will move this to the 2nd gen section (1994-2001 Rams).
Old Jul 26, 2011 | 12:32 AM
a-master's Avatar
a-master
Well, if it was that bad, do an oil change and see if your oil is cloudy (contaminated with coolant). If it is, reach deep, deep down into your wallet and come out with a fat stack of cash. Unless of course you wanna pull the heads yourself
EDIT: This is assuming the engine isn't actually seized up.
Old Jul 26, 2011 | 08:31 PM
alright we already checked the oil to make sure it was not contaminated with anti freeze. it looks good. we filled the radiator back up with antifreeze and water and then filled the battery and charged the battery and still got nothing...
Old Jul 26, 2011 | 10:33 PM
Does it turn over, and just not fire? Or does it not even turn over?
Old Jul 26, 2011 | 10:53 PM
JSTMoto's Avatar
JSTMoto
Can you elaborate a little more? When you say you have "nothing", does that mean the engine is not turning over, there's no power to anything, the engine is cranking but won't start... etc.
Does everything at least power up? (headlights, accessories, etc)
Could be anything from a seized block to a bad fuse....
Old Jul 27, 2011 | 03:11 PM
alright my bad. the truck does start up but when it is running there is this squeaking sound that it makes while running. what do you guys think??
Old Jul 27, 2011 | 04:55 PM
Bob1500's Avatar
Bob1500
sounds like the water pump bearing would be my guess but i would wait for a replie from someone with more knowledge.
Old Jul 27, 2011 | 04:59 PM
Annihilator_X9's Avatar
Annihilator_X9
I 2nd the water pump. Do you know what caused it to overheat?
Old Jul 28, 2011 | 12:54 AM
JSTMoto's Avatar
JSTMoto
If the squeak is from the front of the engine, it could be the water pump as was suggested. Try taking the serpentine belt off (with the truck off of course) and spinning the fan by hand to check for any wobbling, grinding, or squeaking from the water pump.
