engine trouble need help!
#142
#144
#145
#146
#147
#149
It's a dual roller set from mopar performance I have it set on the stock timing marks but I do have the option to advance or retard 4 degrees. It's a Hughes cam and the specs are 208/214 @50 lift 512/520 lift and 114lsa it does thump pretty good at idle more then I was expecting. The timing chain was installed with the cam sprocket ting mark facing down and the crank mark facing up at the cam sprocket timing mark I had my engine builder freind help me with this, he built a couple mopar small blocks so I'm
Confident the cam and crank timing is on
#150
Like I said, I think you have it at #6 tdc. Maybe this will help.
http://www.bionicdodge.com/Download/...uel%20Sync.pdf
and this
http://www.moparchat.com/forums/showthread.php?t=96310
and this
