Transmission experts, please help me answer this one
Can anyone help me I have a trans problem, my 01 RAM 1500 will not shift into 4th gear and/or overdrive doesn't work. Anybody know why this is happening.
Pull your pan and see what lurks inside. Depending on your findings, worst case your pullin the tranny, best case you've got a new filter and gasket. Try a band adjustment while your at it too if you find nothing unusual in the pan.
thanks z, and i replaced my od soleniod becase i lost o/d as weel, but after less that a week i lost o/d again. im gonna bench check the new soleniod and replace the gov transducer and see if it helps
