P0420 after non-fouler trick and cat removed
about a month ago i went with a jegs y-pipe and did the non-fouler to the rear o2. me and my neighbor are starting on my plenum/tune-up tomorrow and wouldn't ya know it i get a CEL today LOL!
i searched for that code and of course it looks to be an o2 problem when people mess with/remove their cat. unless i overlooked it i didn't see anyone who got the CEL after the non-fouler trick.
should i ignore it until after the plenum/tune-up and reset it and see if it comes back (i will be replacing both o2's in the porcess) or should i be looking for something while tearing it down tomorrow?
on
The non-fouler shouldn't cause a CEL, but I've seen changes made to the exhaust cause a CEL and the non-fouler trick NOT work. Doesn't happen often, but it does happen.
Usually, removing the non-fouler and stuffing steel wool in it and putting it back on will get rid of the CEL problem...
I've heard of this, but not too common.
2 things you can try:
a 2nd non fouler with the bottom cut out and double stacked. Takes the O2 sensor even further out of the exhaust stream.
O2 Simulator: http://www.thefastman.com/02Simms.asp
Makes the PCM think the cat is working VERY efficiently. I have had one for about 3 years, it works, and it's passed inspection the last 3 years.
on
Trending Topics
