Forced to down grade 06 to 98
Old 08-06-2011, 09:56 PM
Vader's Avatar
Vader
Vader is offline
Originally Posted by dhvaughan
not on top.
drivers side - down low, hiding behind/right in the middle of, the linkage. has an electrical connector thats hard as hell to get your fingers onto.
Is it bolted in?
Old 08-06-2011, 10:00 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Grab the 01 service manual from the faq section here, and on page 21-583, they have diagnostics for the P/N switch.
Old 08-06-2011, 10:03 PM
Vader's Avatar
Vader
Vader is offline
Will do
Old 08-06-2011, 10:08 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
Old 08-06-2011, 10:11 PM
Vader's Avatar
Vader
Vader is offline
Excellent and available at my local store.
Old 08-06-2011, 10:14 PM
Vader's Avatar
Vader
Vader is offline
Thanks guys, keep the suggestions coming.
I do have a running vehicle.......
http://www.youtube.com/watch?v=SM-KUlqsUac
Old 08-06-2011, 11:07 PM
dhvaughan's Avatar
dhvaughan
i didn't ask any questions, but before you spend $ on that switch, test yours to verify its the problem.
you said you backup lights worked, but not right. i'm assuming that means that if you supply power to them they work, and that they don't work when you put the truck in reverse.
to prove that, unplug the neutral/reverse switch, identify the pins,
test for incoming voltage
jumper the hot wire across to the reverse wire and verify your lights work.
test the reverse switch, and see it fail. depress the plunger thingy and test with ohm meter. you might even be able to clean it and fix it.
Old 08-07-2011, 06:31 AM
Vader's Avatar
Vader
Vader is offline
Thank you for the advice. I will use this procedure to verify my situation.
Old 08-07-2011, 08:39 AM
dhvaughan's Avatar
dhvaughan
i think? that's somehow a 3 position switch that serves 2 purposes.
detect Park and Neutral to allow starter operation.
detect Reverse to switch on backup lights and lock out starter.
detect Forward gears to lock out starter.
Old 08-07-2011, 02:19 PM
Vader's Avatar
Vader
Vader is offline
New neutral safety switch installed, reverse lights operational.
Also, something I typically do not do. I did and oil changed and replaced one quart of oil with Lucas Stop Engine Leak. It has slowed the rear main seal leak until I can get to changing it out.
I am talking to a buddy who wrenches for Dodge to see if he can scan the ABS/Brake lights.
Now, if I can only work up the nerve to try the heater core.
Quick Reply: Forced to down grade 06 to 98
