ABS not working?
Old 08-10-2011, 08:30 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Yes. Disconnect negative battery cable while you swap them out.
Old 08-10-2011, 08:58 AM
Stoft's Avatar
Stoft
Stoft is offline
Ok thanks.. Will try to change the rear one first.
BTW, I had a blue/green plastic wheel with "splines" on it on the tailshaft (?). Looked like this [////]. The speed sensor gear is rolling on that wheel.
Can it be placed in the wrong direction?
Hope you understand me :-)
Thanks
Old 08-10-2011, 09:08 AM
zman17's Avatar
zman17
zman17 is offline
I'm pretty sure it will only go one way.
Old 08-10-2011, 09:19 AM
Stoft's Avatar
Stoft
Stoft is offline
I made a wheel in paper now, it shouldnīt matter beacuse the splines will go from the same corner and up, for example left to right regardless of which direction you put the wheel on.
Maybe i can turn the wheel on the sensor by hand and see if the speedo will move?
Old 08-10-2011, 09:28 AM
Stoft's Avatar
Stoft
Stoft is offline
It is this blue wheel iīm talking about..
I think (And hope that it should matter wich way it is putted on..
Old 08-10-2011, 09:34 AM
zman17's Avatar
zman17
zman17 is offline
Just do the rear sensor first and go from there.
Old 08-10-2011, 09:58 AM
Stoft's Avatar
Stoft
Stoft is offline
Yes, thanks
My last question, IF it would be the "front sensor" (t-case) shouldnīt it shift quiet weird then? Now it shifts like before and O/D is working too?
Old 08-10-2011, 10:00 AM
zman17's Avatar
zman17
zman17 is offline
Yes, the front one will effect shifting.
Old 08-10-2011, 11:23 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
Speed signal is from the sensor in the t-case. At least, I think it is...... If your speedo doesn't work..... that's where I would start looking. The sensor is indexed according to tooth count on the gear in the sensor, if you don't index it correctly, it won't mesh with the gear on the output shaft, hence, no signal.
Old 08-10-2011, 11:33 AM
Stoft's Avatar
Stoft
Stoft is offline
How do i index it correctly? It can only be placed in one position? There are two "claws" that fits in two holes in the sensor. Should I loosen the bolt and then twist the shaft until it snaps in the right position?
Quick Reply: ABS not working?
