torque converter slipped in overdrive
Old Sep 11, 2011 | 02:47 PM
  #31
aim4squirrels's Avatar
aim4squirrels
Precision of New Hampton's stock converters aren't that expensive.
Old Sep 11, 2011 | 03:19 PM
  #32
gdstock's Avatar
gdstock
Precision of Ne Hampton has warehouses across the country. (The one in Denver delivers next day!) I picked mine up in Dallas.
Price is competitive, product quality appears to be excellent, and service is great! I recommend them also.
Old Sep 17, 2011 | 09:30 PM
  #33
2tirefire's Avatar
2tirefire
Finally got around to pulling the transmission, everything went smooth besides when installing torque converter I noticed a counter balance weight. The converter I pulled out did not have one. I spoke with Oreilly's and they said that it was ok and its a improvement to stock converters. So I continued with the installation and sure enough the weight is in the way from seating correctly on the flywheel. So I called Oreilly'sagain and come to find out they ordered a non lockup converter.
I assumed I needed a lockup converter but after looking on Precisions website there is lock up and non lock up for my application. Can somebody confirm which converter I need before I waste some more ATF. Thanks
Old Sep 18, 2011 | 09:01 AM
  #34
You need the locking converter.
Old Sep 20, 2011 | 09:21 PM
  #35
2tirefire's Avatar
2tirefire
Just wanted to update my torque converter R@R. Everything went good besides getting the wrong torque converter from Oreilly's, said it would take 1 week for special order. Couldn't wait that long so I ended up getting a converter from pdqparts.com locally. Just went for a test drive and everything feels and sounds good. I had to chop off the exhaust before the muffler to be able to remove it, got to say the magnaflow sounds good. Glad I didn't get a rebuild for no reason. Thanks for all the help!
Old Apr 15, 2013 | 06:53 AM
  #36
lurk's Avatar
lurk
i have a question about this if anyone would care to answer my father in laws 99 ram 1500 4x4 just poped this code but we just put a transfer case in it that we had to modify to get it in we took the frount yoke out of his old one and put it in the newer one to be clear we switched out the 1.5 in shaft for the .75 in shaft would this have any thing to do with the code showing up?
Old Apr 15, 2013 | 09:41 AM
  #37
gdstock's Avatar
gdstock
Other than a long, run on sentence, I cannot understand what you are asking....
Old Apr 15, 2013 | 10:00 AM
  #38
stewie01's Avatar
stewie01
Nope. That's not gonna set a code, these trucks aren't that smart
What's the code?
Basically he asked if changing the transfer case and having to switch out the 1.5" shaft for the .75" shaft would set the code he has now...
Old Apr 15, 2013 | 12:59 PM
  #39
gdstock's Avatar
gdstock
What's the code?
EXACTLY....What was the code again?
Seems like I saw another thread (or two) about tcase shaft size being changed....
But I am old am not going to chase multiple threads about same problem....
