fluid change tomorrow
Old Aug 13, 2011 | 10:47 PM
chadwall's Avatar
chadwall
Default fluid change tomorrow
Ok, so I'm changing fluids. Oil with high mile Pennzoil 5w30. Tranny with Valvoline atf4. Coolant with tech something from Walmart. And gear oil with 85w140.
The gear oil has never been changed. I read to use 75w140 for front and rear if towing a lot. That's pretty much all this truck does.
75w140 I can only find on full synthetic for $12-17 each (needing 5 for front and rear), and 85w140 is half price. Is it ok to use? A little thicker is all, which I don't think will hurt.
99 1500 5.2.
Old Aug 13, 2011 | 10:50 PM
Don't forget the T-case, ATF +4 there as well.
Old Aug 13, 2011 | 11:25 PM
chadwall's Avatar
chadwall
Yes. But the 85w140 ok, no limited slip.
Old Aug 13, 2011 | 11:32 PM
dodgeram07's Avatar
dodgeram07
since you have the pan off install a drain plug its only like 3bucks but will save u alot of time down the road
Old Aug 13, 2011 | 11:39 PM
SilverSS's Avatar
SilverSS
I think they recommend the 75-140 for towing mainly because it is synthetic- but I'm not sure how the viscosity affects it also. I personally am not a fan of synthetic in the diff's.
Old Aug 13, 2011 | 11:44 PM
80omni's Avatar
80omni
if your towing i would run synthetic for sure. if you deside otherwise the 85w140 will be just fine it will be a little thicker when cold but will be the same viscosity at operating temp
Old Aug 14, 2011 | 12:03 AM
chadwall's Avatar
chadwall
Awesome. I don't care about synthetic unless it'll ruin it. Drain plug was installed in tranny 3k ago by guy that rebuilt it. Beat thing ever!
Old Aug 14, 2011 | 12:56 AM
chadwall's Avatar
chadwall
Also, its not bad to drink beer while doing fluid change, even if I'm doing it in the am right?
Old Aug 14, 2011 | 08:16 AM
zman17's Avatar
zman17
Retired Moderator - RIP
No not bad, might as well change your fluids too.
Old Aug 14, 2011 | 08:49 AM
chadhager03's Avatar
chadhager03
Can you run royal purples synthetic transmission fluid in the tc and tranny?
