What do you think?
Old Aug 23, 2011 | 09:57 PM
Josheis's Avatar
Josheis
Smile What do you think?
Just did this yesterday, debating on blacking out chrome as well been trying to get opinions on which will look better. Also I'd hate to make two threads, what would cause my transmission to have delayed shifts and feel like its being held back when cold but drive fine and spin the tires while warm. I'm removing check valve tomorrow on my day off. A few notes I believe I have the 46RE, transmission fluid is almost clear doesn't smell burnt and no abnormal noises just delayed shifting when cold. I'm not used to auto's so if this is normal great but god I wish it was five speed.
Old Aug 23, 2011 | 10:32 PM
Looks good!
When was the last time the fluid/filter in the trans was changed? If you don't know the answer to that question, it's been too long. While you have the pan down, inspect the governor pressure sensor, and solenoid. They like to get gummed up, and not work as they should. If your truck is approaching/past 100K miles, won't hurt to do a band adjustment either.
Old Aug 23, 2011 | 10:59 PM
Josheis's Avatar
Josheis
Doing fluid and filter on next pay check bought at 100 now its at 106, want to do band adjust just don't wanna damage it, what should I check on the solenoid and sensor?
Old Aug 24, 2011 | 10:54 AM
They like to get clogged up with the assorted crap that naturally accumulates in the pan. Clean 'em out good, or, just replace them while you are in there if they are really bad.
Old Aug 24, 2011 | 12:31 PM
Josheis's Avatar
Josheis
So just clean them with like brake cleaner? Or what lol? I'm pretty good with engine and body work just not tranny's yet lol. And do I need a torque wrench for any of this? Governor, filter, pan bolts.
Old Aug 24, 2011 | 12:32 PM
Brake or carb cleaner should work pretty well. If you adjust the bands, you will need a torque wrench that is accurate at 72 inch pounds. That's it.
Old Aug 24, 2011 | 12:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You'll want a set of torx sockets too. At the very least, the filter uses torx heads.
Old Aug 24, 2011 | 01:34 PM
redheadhunter21's Avatar
redheadhunter21
Cold fluid will cause this, what is the temperature outside
Old Aug 24, 2011 | 07:59 PM
tweav88's Avatar
tweav88
In my opinion chrome is awesome and there a very few trucks "blacked out" that actually look good, some do but the majority don't to me.
Old Aug 24, 2011 | 08:08 PM
JackJ's Avatar
JackJ
See quote it sig.
Also I was able to use allen keys to remove filter from trans, they are not very tight and torx tips can be expensive to get a good kit that is not gunna brake just by looking at them wrong.
