no spark 1997 5.9 1500
Old Sep 6, 2011 | 09:16 AM
It will only be powered for about three seconds, or, if the engine is actually cranking. If the PCM doesn't see signal from the cam/crank senors, it will just shut off the coil and injectors.
Are you actually getting spark while cranking?
Old Sep 6, 2011 | 07:18 PM
welchj69's Avatar
welchj69
no spark at all when cranking just power for 3seconds
Old Sep 6, 2011 | 11:09 PM
I wish there was a good test for the crank sensor... but, there isn't one I am aware of. Get one from the dealer, and replace yours. I think it's dead.
Old Sep 7, 2011 | 04:56 PM
welchj69's Avatar
welchj69
I just replaced it and it works in buddys truck
Old Sep 8, 2011 | 09:23 AM
Do you get voltage back at the coil while cranking?
Old Sep 8, 2011 | 10:42 AM
kurts2's Avatar
kurts2
Did you ohm ck the wires from the crank sensor back to the PCM? Now that you get initial power at the coil, it the sounds like a crank error.
