thumping in steering wheel
Old Aug 27, 2011 | 11:49 PM
mgaither0's Avatar
mgaither0
Default thumping in steering wheel
so my truck has a noticeable thump in the steering wheel when i go over bumps and stuff. I also have a slight knocking noise when i pick up to higher speeds on the highway. The shop didnt find any problems. Any ideas?
Old Aug 28, 2011 | 01:44 AM
Kraiger's Avatar
Kraiger
check the swaybar bushings
Old Aug 28, 2011 | 07:02 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could also be the steering column bushing. http://www.rocksolidramtrucksteering.com/
Old Aug 28, 2011 | 08:10 PM
jmhai's Avatar
jmhai
I installed it last weekend and it did as described...
Tighten up the steering wheel real nice. The bearing that is in there was so thin and flimsy I can't see it was any good to begin with when new..
Old Aug 30, 2011 | 06:44 AM
mgaither0's Avatar
mgaither0
jmhai, were u experiencing a noticable thumping feel into the wheel or anything? zman thanks for the link that looks promising. any way to determine if these bearing are bad, the sway bar bushing or steering colum bushing? Besides obviously looking at it and seeing the bushing is shot. thanks
Old Aug 30, 2011 | 07:44 AM
zman17's Avatar
zman17
Grab the steering column where it comes out of the firewall under the brake booster. If it wobbles up and down and or sideways, the bushing will fix it.
Old Aug 30, 2011 | 02:31 PM
keith97's Avatar
keith97
So how bad is this upgrade to do.. What does it intell do you have to pull the column or what?? how do you replace theese pieces..
Old Aug 30, 2011 | 02:32 PM
You don't have to pull the column, but, doing so makes it easier. I think they have the instructions posted on their website somewhere??
Old Aug 30, 2011 | 04:30 PM
jmhai's Avatar
jmhai
Not thumping really. mostly felt it getting in the truck pulling on the steering it would move alittle or with no steering turning pressure left or right I could grab the wheel at 12 and 6 and move up and down alittle more like tilt(pivot) cause the bearing near the wheel is fine. Also when driving at different times feel it tilt/pivot..
I also did the test zman17 suggested and it was not too bad, but I did feel a wiggle..
I did not remove the column, did it in the truck with a dremel tool to cut the spring and retainer clip and the old bearing just really wiggled off by hand a little grease new bearing/clip and all done. now that I did it, could do again in about 15/20 minutes.
Old Aug 30, 2011 | 04:59 PM
Cloak's Avatar
Cloak
I hope it gets rid of the little bit of "sawing" I do ....I hate that......
JMHAI....you said its a piece of cake? Any tips?
