Windows always fogging up w/ heater or AC
Old Sep 1, 2011 | 12:46 AM
Polishdog's Avatar
Polishdog
Default Windows always fogging up w/ heater or AC
Smells like a burning odor when I turn on the heater. The windows fog up instead of clearing.
Any ideas? Bad heater core? I didn't notice any leaking.
Old Sep 1, 2011 | 12:55 AM
SilverSS's Avatar
SilverSS
More than likely heater core. If it's not leaking yet it probably won't be long.
Old Sep 1, 2011 | 03:02 AM
CappinHoff's Avatar
CappinHoff
I agree with the previous poster as well. You won't always notice leaking. Does your window have a greasy film on it? If so it's the heater core.
Do a search for a DIY. Or look at this one.
https://dodgeforum.com/forum/2nd-gen...ater-core.html
Old Oct 7, 2011 | 07:21 AM
skuzatko's Avatar
skuzatko
ok guys, heres one, 2000 dodge durango, got great heat, windows have just recently started fogging up and stay fogged up even with warm air blowing out. No ieaks on the floor, no wettness on the carpet, do smell the hint of antifreeze. Notice a ton of moisture coming from engine compartment as if a/c was on. What do you think?
Old Oct 7, 2011 | 09:05 AM
Your heater core is leaking, and draining out the a/c condensor drain.
Old Oct 7, 2011 | 11:00 AM
LcknLoad's Avatar
LcknLoad
Probably Heater Core. Happened to me but i had leakage on the passanger side floor.
Old Oct 7, 2011 | 11:15 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I don't know if anyone has suggested this, but it sounds like your heater core is leaking.
Old Oct 7, 2011 | 01:43 PM
jlowmiller's Avatar
jlowmiller
Might want to look into washing your windows too.
Old Oct 7, 2011 | 02:51 PM
blackbeasst's Avatar
blackbeasst
not to hijack the op's thread, but what if there is no leak, no smell, no fogging, but yet the heat works but very sporadically and better on the low levels then high? still heater core?
Old Oct 7, 2011 | 02:59 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
That means either the heater core the hoses, or some other part of the cooling system is clogged.
