po601
Old Sep 8, 2011 | 08:27 PM
fred1967's Avatar
fred1967
Default po601
anyone know what po601 means in the trouble codes
Old Sep 8, 2011 | 08:28 PM
pcfixerpro's Avatar
pcfixerpro
It means you need to replace your computer.
DO NOT replace it with one from autocomputerexchange. They are horrible! Go local. Get a reman unit done by cardone. Once I got a good one, no problems since
Old Sep 8, 2011 | 08:32 PM
fred1967's Avatar
fred1967
can the computer be reflashed or is it going to be junk soon? its not misssing in fact its running fine
Old Sep 8, 2011 | 08:35 PM
pcfixerpro's Avatar
pcfixerpro
This page can set you straight.
http://www.obd-codes.com/p0601
Just trust me, don't go through ACE, They jerked me around and after 2 computers from them (neither worked), I gave up. You are correct that you don't notice any driveability concerns... so as long as you don't need inspection, you'll be good for a while. That was the reason I knew I had to replace mine sooner or later. To answer your question, no a flash won't fix it. To complicate things with mine, my code was set while I had my superchips flash in there... and couldn't un-program it lol.
Old Sep 8, 2011 | 08:36 PM
has your gas mileage changed at all? You could try resetting the PCM, (disconnect the battery for a couple minutes) and see if the code comes back. If it does, you should replace it.
Old Sep 8, 2011 | 08:40 PM
pcfixerpro's Avatar
pcfixerpro
It doesn't show up right after you pull the cable. However it does return on a test drive or two afterwords. You can't get rid of this one without pcm replacement.
Old Sep 8, 2011 | 08:56 PM
fred1967's Avatar
fred1967
like you i also have a superchips tuner in mine thanks for the advice
Old Sep 8, 2011 | 09:04 PM
pcfixerpro's Avatar
pcfixerpro
Hopefully you have a 3815 or a 3865. Your going to have to call superchips, explain what happened and see if they can fix you up. They took care of me.
